Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Is 11.5 Quarts Of Oil OK?
I looked at my manual and it states about 10.5 quarts. I changed the oil last night and the dealer forgot to give me the two crush washers so I let it sit all night to drain until I could get the washers this morning.
I added 1/2 of quart of oil to the filter before I installed it and then added 10 quarts. I let it warm up but the needle never moved off of the red so I added another 1/2 of quart to make it 10.5 but the needle still didn't move.
I ended up adding a total of 11 quarts and then went for a short drive to see the needle move up to 3/4 of the way to full. Got back and checked the oil to find its still about 1/2 low. Is it normal to take 1 full quart more then the manual suggest?
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-20-2008, 05:59 PM
Max Sluiter
Flieger's Avatar
I have a 1971 911S with a 2.7 RS spec and a front mounted oil cooler. It has a total volume of about 11 quarts. I need a little over 9 quarts to get it full after an oil change. Your oil volume sounds like a good amount. It is midway between the marks at operating temperature at idle on a level surface?
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 06-20-2008, 06:05 PM
Yes, a little over 1/2 on the dip stick. It sits in my garage which is flat.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-20-2008, 06:07 PM
Max Sluiter
Flieger's Avatar
Sounds fine to me.
911S
Old 06-20-2008, 06:24 PM
Just changed mine 88 930, yesterday and added 11 quarts and dipstick read half way between the two lines exactly the same as your car. Relax and go for
a cruise now............
Old 06-21-2008, 11:34 AM
Thanks but couldn't the needle on the dash be up in the white section? Mine is in the middle.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-22-2008, 04:20 AM
A fellow Pelacanite
NathanUK's Avatar
So, if the stick says it's half way and gauge also says half way then that is excellent. The gauge is working prefectly.
Of course it's better to trust the stick, but the gauge might give you an indication if you had a big leak.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-22-2008, 04:46 AM
I topped it off today with another 1/2 quart (11.5) and all is well now.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-22-2008, 03:57 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
