Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
tach stops at 4500-5000 RPM when air temp is hot
Tach is operational through the entire range when the air temp is cool... when it is hot out ( 85-95 degrees) the tach will operate up to 4500-5000 rpm and then stops.. doesnt fall back just stays at the 4500 rpm level and when the engine falls back below that RPM it starts registering again.. Anyone experience this problem or know what the repair might be...other than sending it out for rebuild....Thanks
1987 930 -Guards Red
2001 740I sport Blk
2011 F-150 supercrew Blk
2014 X3 2.8 white
"What goes around comes around..."
Old 06-21-2008, 12:21 PM
Crotchety Old Bastard
RarlyL8's Avatar
Not an uncommon problem in our aging cars. A couple of things cause that. One is the glass moving as it heats up. The tach needl will actually touch it and freeze. Another is diodes that get hot in the sun and quit until they cool off.
Typically the tach will begin working again once you get air moving throught the vents.
Old 06-21-2008, 01:07 PM
thanks brian... the diodes you speak of.. are they in the cdi box or are they part of the tach gauges internal electronics?
2001 740I sport Blk
2014 X3 2.8 white
Old 06-22-2008, 08:26 AM
brian ... is this the diode in the cdi box ????
2001 740I sport Blk
2014 X3 2.8 white
Old 06-22-2008, 08:33 AM
Sorry ... this is the CDI box schematic
2001 740I sport Blk
2014 X3 2.8 white
Old 06-22-2008, 08:39 AM
RarlyL8's Avatar
The tach itself. The dash gets hot in the sun which affects the old electronics.
Old 06-22-2008, 09:14 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
