Originally Posted by NathanUK View Post
Yikes, well spotted, yep, looks like you would need to cut them to get the disc off. I guess if you make a good job of cutting out a neat circle and you could live with it you would be fine.
Luckily neither of my cars have the fins!
Since you don't have the fins do you get a lot of "damage" on your quarter panels?
I always thought the car looks better without the fins and I always wondered why people don't just rip them off.
Old 06-26-2008, 06:59 AM
Large Member
krasuskyp's Avatar
Bernard - where did you source your clear 964 fins, and how much if I may ask? If I have to peel mine to clock my torsion bars I want to price out all my options first.
I really love the look of the clear on your slate blue, and have always dug how the black cars are so muted and monchromatic. However I have ALSO always dug how the Gran Prix and Guards cars have all the black accentuations. I'll have to Pshop off mine in a photo and see what I think clear'd look like I guess. Gots to get it lowered, soooo...
Thanks.
ps. speaking of Aero mirros... anyone ever notice 911 mirrors are asymetrical in mounting points side to side? Buddy pointed it out to me last night, now it's all I see! Weird. Either I'm a noob and everyone knows this or...
Paul... CT | '87 930 | '07 //S6 v10 JNR | '98 ///M3 vert |
past:
| '01 ///M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 //S8 | '95 //S6 6gang | '88 ///M5 | '87 190E 2.3-16 |
Old 06-26-2008, 08:48 AM
Crotchety Old Bastard
RarlyL8's Avatar
The front of the rear fender flare will take a beating without some sort of stone guard.
I left those off of my car due to the brake duct hole in the aftermarket rocker covers. Big mistake. The entire area was sand blasted with rock chips the first summer. I would now have to do a repaint before finding some way to cover and protect the area.
Old 06-26-2008, 09:24 AM
Sorry about the wrong info... The rear stone guards are off a 997 not a 964. The part numbers are P997-504-825-02 P997-504-826-02 They were about $38 each.
They wont be an exact fit, you will have trim some off the bottom and also remove the lower rubber trim to install it. The best why to do it is with soap/water to allow you to move it around until you find the right place for it.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-26-2008, 02:41 PM
Large Member
krasuskyp's Avatar
Thanks Bernard!
past:
Old 06-27-2008, 05:24 AM
onboost's Avatar
Paul,
All one has to do is apply the film with the torsion bar cover removed. Use an xacto knife to cut out the whole.. finish the application and then apply the cut-out piece to the torsion bar cover. Trim as needed on both areas and you're done! That simple.
AS Rarely stated, the front of the rear 1/4s will be peppered by the end of the summer without some kind of protection.
As far as the mirror position is concerned, they are placed so that with a properly adjusted seat, and properly adjusted mirrors.. you almost don't have to turn your head to look into the mirrors... just cut your eyes to the right through the 1/4 glass on the pass side and the mirror should show whats there.. on the drivers side it's a quick glance out the full side window..
I know that's all it takes for me if positioned properly... besides, that's all you have time for at triple digit speeds!
Paul
RGruppe #180
Old 06-27-2008, 08:09 AM
Large Member
krasuskyp's Avatar
Thanks Paul.
I assume you mean this is after buying NEW film, and then being able to have unfettered access to the covers?
I was sorta wondering if you could cut the film on there now and remove the cover with it on, then reapply and just have a seam. Look ridiculous? Source of moisture trap? Be OK? Or do you have to peel it off the cover itself to get the cover off?
If I peel it I'll have to decide black again or clear. And, no, no way I'd run the car sans - it's evident by looking @ the film how effective it is.
Oh I know the reasoning on the mirrors (but thanks!), just never noted it and now it's all I see 8-).
Tx again.
past:
Old 06-27-2008, 11:13 AM
A fellow Pelacanite
NathanUK's Avatar
My car does have a few specks of damage, I have no idea how many miles it has done since it was last painted though.
As for the mirrors, it's yet another reason not to convert LHD to RHD or vica versa!
Paul, I'd try to cut out the disc of your black film neatly and then refit the disc. If you're not happy then get new fins.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-28-2008, 03:48 AM
onboost's Avatar
Originally Posted by krasuskyp View Post
Thanks Paul.
Tx again.
Ok, I see... but yeah, you can still cut it with an xacto. Does not look ridiculous at all, have seen a number of them like that, its the only way to adjust the bars.
I don't see it as a water trap either, you could always use a thin "finger wipe" of silicone around the edge of the cover as well as the hole on the car, or use a rubber seal like the other 911s.
Paul
RGruppe #180
Old 06-29-2008, 05:05 PM
Large Member
krasuskyp's Avatar
Great advice - appreciate the thoughts Paul - will do!
past:
Old 06-29-2008, 07:23 PM
onboost's Avatar
Paul,
No problem.. looks like I'll adding the clear fins as well with much cutting.
I have vents in my 1/4 panels, just removed the slats to clean it up well to add the clear pieces. Ordered those yesterday!
Good luck with yours.
Paul
RGruppe #180
Old 07-01-2008, 07:25 AM
I got the clear bra installed on the front bumper Saturday. Being their was no kit out for the Turbo 964 bumper that I could find I had my guy custom install it and he did a great job. I also has him custom cut one on the Corrado too.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 07-01-2008, 05:24 PM
resident samsquamch
sand_man's Avatar
sand_man is a big fan of the Corrado...
-jeff
Old 07-01-2008, 08:16 PM
After the next project
x98boardwell's Avatar
Another Fan
Bernard,
I also love the Corrado's. They bring back some teenage memories. I have owned 8 VW's and always liked the looks of the Corrado's.
It is nice to have 2 fun cars to drive. Great looking rides!
Bryan
Old 07-03-2008, 12:30 PM
Thanks Bryan... I just picked it up a few weeks ago from the original owner. He's also a big Porsche fan. He has a super clean 928 GT and an older 911. This Corrado is in showroom condition with every service record to back it up. I just installed a 2.5" exhaust from the down pipe back. I'm also added a Turbo to it which will put down close to 300 HP.
I just sold my old Jetta coupe Turbo which the power was just un-real.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 07-03-2008, 02:06 PM
