mlhm5's Avatar
Conversions
*500cc per minute is approximately equal to 49lbs per hour which is equal to approximately 100hp.
* lbs/hour = cc per minute / 10.5
* lbs per hour = HP / 2.04
* cc per minute = lbs per hour x 10.5
* cc per minute = HP x 5
* HP = cc per minute / 5
* HP = lbs per hour x 2.04
Old 07-17-2008, 07:08 AM
lite75's Avatar
Anyone running full sequential?
75 930, 76 930, 83 SC EFI turbo
Old 07-17-2008, 10:02 AM
beepbeep's Avatar
Minimal power gains. Good for emission and idle quality. Good for odd-cylinder engines and big injectors (like Audi 5-cyl etc.) but doesn't really matter when it comes to power. Will idle smoother tough.
Thank you for your time,
Old 07-19-2008, 04:05 AM
magic930's Avatar
Running sequential on mine, it doesn't make any difference after about 3500 rpm though.
Old 07-19-2008, 07:38 AM
930gt-40r's Avatar
I got full sequential running my car, Im thinking about changing it though
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 07-20-2008, 08:37 AM
I am running 72lb/hr Siemens in full sequential with a Motec M600 it is currently in Geoffrey Ring's hands and I hope to have it back sometime...
Old 07-21-2008, 06:00 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
96lb/hr
full sequential
13.2 AFR at idle
652@ 1 bar
771@ 1.5 bar
My injectors are actually too big, I should use 72's or even 83's, I don't really care to have the BIG numbers. I am happy at 1 bar. My injectors are set to .25ms which is the lowest they really can be fired, if I go lower they don't fire consistantly and the idle rolls too much and runs rough. I get the car to idle at 13.2-13.5 and stays clean enough not to foul the plugs.
As Goran stated, sequential is only useful for idle, once on boost batch is fine unless you are running serious power and then stagged injectors would be desired.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 07-21-2008, 07:26 AM
A fellow Pelacanite
NathanUK's Avatar
What's the reason? Cooling? Flames?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-21-2008, 10:27 AM
beepbeep's Avatar
There is no drawback with running sequential injection except more expensive EFI and more complicated cabling. If possible, it should be used. But it doesn't matter on the track.
Old 07-21-2008, 11:09 AM
