Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Engine smokes at idle
After a run hard enough to open both thermostats, I get oil smoke coming from the right rear seemingly from directly above the muffler. There is no smoke coming out the exhaust. I also noticed some standing drips on the bottom of the oil line running to the fenderwell thermostat, so I bought a new line from Pelican but it seems you can't get at the thermostat to remove it.
What am I missing here?
Larry
Old 07-07-2008, 03:50 PM
A fellow Pelacanite
NathanUK's Avatar
Valve covers?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-08-2008, 11:44 AM
Macht Schnell
les_garten's Avatar
A Porsche leaking oil! Have you notified Zuffenhausen? Have you been watching it closely at night? It could be hanging out with some '65 Harley Panheads!
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 07-09-2008, 04:40 AM
beepbeep's Avatar
hehe.
Check:
Oil-return tubes
Valve covers
Cylinder bases
Thank you for your time,
Old 07-09-2008, 09:18 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
