F350Lawman's Avatar
Thumbs up OK lets pend some of my money$$$
Since you guys did such a good job helping me redo my suspension and bank account last year (especially A930rocket and Craig 930 RS)..I figured who better to help me rebuild my motor!
The goal is a minimum of 400whp and dependabiltiy in car that is driven fairly often(about about 3-4K a year) and does 6-8 DEs a year. I am looking to stay with CIS as budget is a consideration. The car is modified as listed below and appears to have a bad ring as we speak, so will get rebuilt when the cold weather comes and my wrench is available. What I am looking for is the best dollar for dollar solution.
When the engine comes out I am also planning for a Guards LS to be going in the open diff. tranny and the clutch will be replaced. Also have my buddy ready to do a repaint and install a full cage connected to suspension towers while everything is out. Suggestions welcome there as well.
With the suspension, zork, cage, etc. the car is really becoming more of a "track car" that is driven on the street which I like just fine.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 07-07-2008, 07:00 PM
Crotchety Old Bastard
RarlyL8's Avatar
I don't think you'll need much help spending money, ha!
The 400WHP CIS formula is pretty easy and not terribly expensive parts wise. You already have most of what you need:
BS Intercooler
Headers
Zork
1.0bar WG
Adjustable WUR
Now add:
SC330 Cams
Ported Heads
K27HF or similar Turbo
AFR Tuning
Cam Timing
Ignition Timing
Results should be full boost before 2600rpm, 400WHP, 21+mpg @ 70mph/4th gear
Old 07-07-2008, 07:24 PM
Me like track days
Craig 930 RS's Avatar
Yep. Sure sounds like it's gonna be like my car!
So here ya go -
964 cams
K27 HF Turbo
**911 SC HEADS**
Track days:
You WILL need additional oil cooling - bank on it!
AND get the AFRs spot on
400 at the wheels is yours!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 07-07-2008, 08:41 PM
F350Lawman's Avatar
BS Intercooler
Headers
Zork
1.0bar WG
Adjustable WUR
Now add:
SC330 Cams
Ported Heads
AFR Tuning
Cam Timing
Ignition Timing
930 heads or are we talking about SC heads? Do you think the best source would be this board or are there others you could recommend for the cams/heads?
So here ya go -
964 cams
K27 HF Turbo
**911 SC HEADS**
Track days:
Yes it is going to be like your car, I am not a proud man..I will copy what works for others everytime. It is too expensive to pioneer with these cars. Besides you guys did a bang up job designing my suspension!
I am already looking at which spoiler/cooler setup I like. Think I might go with the IROC spoiler, we'll see.
Old 07-07-2008, 09:13 PM
RarlyL8's Avatar
I forgot to add that you will likely need additional fuel to support 400WHP, how much depends on a lot of things such as your choice of components and tuning. That will bear itself out when you check the AFRs on the top end.
There are lots of ways to get to 400WHP, what I have listed is one of the least expensive as it uses most of the parts you already have. The 7200 is still popular and has resale value.
Old 07-08-2008, 06:34 AM
F350Lawman's Avatar
The fuel head will get looked at, right now without taking it off my mechanic thinks the PO had it modded because we flow plenty of fuel and it looks very 'clean and shiney' compared to the surrounding pieces. Yeah, my 7200 works fine and I will sell it or trade it in. Wasn't there a guy on this board (or maybe the other board) taking 7200s and rebuilding them for $1000 to your choice of HF or HFS specs????
Old 07-08-2008, 06:49 AM
RarlyL8's Avatar
Yes, the manufacturer of the K27 series turbos, Kevin, will rebuild your 7200 to Hf/S specs for $1K. I've spoken to him myself about that.
Old 07-08-2008, 08:31 AM
Me like track days
I'd sell the 7200 and buy a K27 HFS outright from Kevin - I believe you'll come out ahead $-wise. Ask Kevin: kevin@ultimatemotorwerks.com
Kevin lives near my house, great guy and the man for a turbo for your 930.
As Brian and myself have mentioned on other posts, do all the things you wish, and *then* check/adjust your AFRs before getting the IA fuel head. Chances are you won't need it -
Old 07-08-2008, 08:45 AM
David's Avatar
I'll second the 964 cams. I have them in my EFI car and they seem a little tame so they should be fine with CIS.
2014 Cayman S
2011 Cayenne Turbo
Old 07-08-2008, 01:39 PM
RarlyL8's Avatar
If the goal is 400WHP I would budget for added fueling. The break point seems to be somewhere around 375WHP depending on the mods.
Old 07-08-2008, 01:53 PM
Buy my spare engine and you will have over 400 hp.
Old 07-10-2008, 09:39 PM
Me like track days
Yep, additional cooling is a MUST - I have 3 oil coolers, and for track use it works well. 3.
You will need at least 2 ;-)
Don't kid yourself. 2.
Old 07-11-2008, 10:58 AM
speeed racr, how much is your spare engine and what are the specs? I have been gathering components to build an engine, but it just might be easier to buy yours.
Old 07-11-2008, 05:21 PM
F350Lawman's Avatar
It appears thta my fuel head was modded already, we'll see when it comes off.
The HFS has been on my list for awhile, it sounds like most recommend it.
I am looking at front spoilers and oil coolers and trying to decide what to get. I will run the 3 coolers and the oil cooler scoop that I replaced the side light with, so it should be fine.
Old 07-11-2008, 08:16 PM
