-   -   CIS Injector Torque Value (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/419242-cis-injector-torque-value.html)
DSPTurtle 07-10-2008 08:16 PM
I went through the search function, my manual and a google and don't seem to be smart enough to find the torque value for the CIS injector to intake spacer block.
Anyone know the proper torque value? I installed new copper gaskets so I want to make sure I get the injector seated and the washer crushed to the correct value.
Thanks in advance!!!
DSPTurtle 07-11-2008 10:39 AM
I am going with 10 ft lbs at this point unless someone has a better plan???
NathanUK 07-11-2008 12:42 PM
Is it not in the SC manual?
NathanUK 07-11-2008 12:53 PM
It is in the 930 manual. 5lbs ft.
boostfix 07-11-2008 01:02 PM
what page Nathan? I looked this morning and could not find it.
NathanUK 07-11-2008 01:46 PM
10-06 states Injection Valve 5ft.lb
25-1 confirms the name of the part and the quantity on the car.
DSPTurtle 07-11-2008 09:05 PM
Hmm... section 10 in my manual is all about removing the engine and transmission. Regardless, I will trust your research and stick to the 10ft/lbs that I torqued them to and call it a day. Thanks for following up!!!
NathanUK 07-12-2008 04:45 AM
No problem. 5lbs doesn't seem a lot but then again those blocks are not very strong IMO.
boostfix 07-12-2008 07:20 AM
Injector Torque Specification
Nathan is correct:
http://forums.pelicanparts.com/uploa...1215872390.jpg
NathanUK 07-12-2008 07:51 AM
Yep, that's 10-06.
DSPTurtle 08-16-2011 06:46 PM
I just had this exact question again 3 years later and found this thread using the search function. LOL!!! I was about to post this question again. Hahahahaha
