Wildcat96's Avatar
SC Cam Question
Hi All,
My 81 930 is currently at Imagine Auto for a new clutch, cross threaded spark plug fixed, and oil leaks taken care of. I was talking to a friend this morning that was telling me I should have SC cams installed in the car since the head was off. My car is completely stock and would appreciate your opinions about SC Cams.
1.) How would SC Cams affect the power delivery on a stock car?
2.) Would I need to change the exhaust, Etc to accomodate the SC Cams?
3.) Would SC Cams affect the long term longevity of the motor?
4.) What is the average cost of a cam replacement?
5.) Are there any drawbacks to replacing the cams on a stock car?
Thanks for your input!!!!
Current / Previous Cars
1981 930 Turbo (Current)
2004 Audi A4 Quattro (Daily Driver)
2000 Boxster S (Sold)
Old 07-12-2008, 07:11 AM
DSPTurtle's Avatar
I was really close to doing this until the "while you are in there" list started to get too crazy so I stayed stock. If you are replacing the cams you should also increase the port size of the intake. Also you can mill the head and cut the cylinders for the fire ring. Once you start to figure all that stuff out it just makes everything crazy.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-12-2008, 08:42 AM
Cymru am Byth
carmad's Avatar
I had my stock cams reground to SC profile, off boost, engine is more responsive for better drivability and gain in HP. If you are going to change the cams, you should do the other upgrades, turbo, exhaust, headers etc, these are easy bolt ons, and you can do them as money is available.
You should talk to Stephen at Imagine, he's the man.
Glad I did it.
1986 930 (Gone but not forgotten)
1995 993
2007 BMW 328Xi Sport Wagon
2005 Lexus GX470 Offroader
Julian Williams
Old 07-12-2008, 09:44 AM
DSPTurtle's Avatar
Julian, did you port the heads when you changed cams?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-12-2008, 10:12 AM
Crotchety Old Bastard
RarlyL8's Avatar
All '81 930s are 300HP Euros. The stock exchangers are pretty good.
You don't need to remove the heads to change the cams. They are easier to change with the engine out of the car though.
SC cams are great. I have them in my engine with a K27-7200 and stock Euro exchangers like you have. Heads are stock as well, no need to port them unless going after big power.
You should consider a more modern turbo if yours is still stock. HUGE difference when combined with a cam swap.
How much? Pricing is subjective. If the engine is out of the car it is a couple hours work to R&R and dial them in. They should adjust the valves while at it.
Old 07-12-2008, 10:53 AM
Cymru am Byth
carmad's Avatar
DSp Turtle,
Had the heads completely rebuilt, but did not port them, decided I was not going to try to make big HP, just good solid reliable HP, so left them stock.
1995 993
Julian Williams
Old 07-12-2008, 02:22 PM
Greg
Gregsgroup's Avatar
Can anyone give a comparision of the differences of using either the SC or 964 cam specs in a stock (for now) 930. Also, any suggestions on who to use to regind the stock 930 cams to either SC or 964 specs.
I love this place...
Old 07-12-2008, 03:45 PM
DSPTurtle's Avatar
We were going to send mine to Web Cam before I chickened out on it. Apparently they are one of the best for the regrind.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-12-2008, 03:50 PM
mppickett's Avatar
I considered the SC cams but finally went with 964s. John Dougherty is a real expert and posts often on this board. His site has the lifts and durations on virtually all of the cams we might use http://www.drcamshafts.com/911profiles.htm
The 964 cams are just a little bit more aggressive than the SC cams and still are very streetable in our engines.
07 Audi A4 2.0T Cabriolet - Black/Black (sold)
96 993 C2 Cabriolet - Arena Red/Tan (sold)
82 911SC - 993 Turbo Cab Trib - Speed Yellow/Black (sold)
58 DKW Universal - Baby Crap Yellow/Beige (sold)
Old 07-12-2008, 05:26 PM
jbailey930's Avatar
Send a message via AIM to jbailey930 Send a message via Yahoo to jbailey930
SC for me. Per Stephen's recommendations along with opening up heads, Carrera intake, Motec, yada yada. Very nice off boost. 5k miles on rebuild and love it. Webcams did the grind, timed well on install.
YMMV
John
79 930
Old 07-12-2008, 05:43 PM
Greg
Gregsgroup's Avatar
What's the typical cost for a regrind to SC specs?
Old 07-12-2008, 06:07 PM
Wo ist die Rennstrecke?
DonE's Avatar
Here is a money saving tip on cams for street cars. Since these are forced induction systems and low compression ratios, you are not going to gain that much with different cams until you open up the rest of the system. In the mean time, do two things: advance the cams for improved low end response and then make sure the valve lash is dead on. You will notice a difference without replacing a thing. My favorite cams on my CIS car were 964's.
Old 07-12-2008, 06:09 PM
A fellow Pelacanite
NathanUK's Avatar
So you don't think a 964 cam is overkill on a 3.3 with stock heads & CIS?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-12-2008, 11:43 PM
Cymru am Byth
carmad's Avatar
I used WebCam, IIRC, cost was about $700.
1995 993
Julian Williams
Old 07-13-2008, 06:16 AM
DonE's Avatar
Cams are the heart of the motor. The motor is an air pump and the cams manage the air flow thru lift and duration of the valves. The stock, SC and 964 cams all do well on a reasonably stock motor given this is a forced induction motor. If you use your car for street use, I doubt you'll notice a difference if nothing else is changed. On a dyno, you'll see a difference. If I remember correctly, when I went from SC to 964 cams, I got about 20 hp on top. Then I started playing with the timing and found I could feel the difference on low-end off boost throttle. If I wanted top end I would have retarded the timing.
My point is, just changing the cams on these motors is not like changing cams on a naturally aspirated motor. There are better places to spend money - like like try a straight pipe or straight through muffler for a real kick on a stock motor (get rid of post-turbo back pressure).
Old 07-13-2008, 06:30 AM
RarlyL8's Avatar
I completely agree with that, but he is thinking about the "while I'm in there" aspect of changing cams.
If he wants to change them at some point but doesn't plan to do it himself it should be less expensive to do it now while the engine is out and apart.
I'd get a quote for the added work to be sure.
Old 07-13-2008, 06:46 AM
Gregsgroup,
The two mentioned, John Dougherty & Webcam, charge IIRC $275 for a regrind. I am no expert, but in my reasearch if you use SC cams from an SC a "boss" is missing to run the scavenge pump? Now that you are looking at cams, you have to decide SC or 964? Here is interesting reading
euro 1982 turbo with 964 cams question
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 07-13-2008, 09:22 AM
Wildcat96's Avatar
Thanks everyone for your input!!
I think I'll stay stock for now.....
Can't wait to get the car back as it's been at the shop almost a month and it's a beautiful day today. Guess I'll have to take the Camry for a drive instead.
Old 07-13-2008, 10:04 AM
Before you give up, check with Stephen @ Imagine Auto. he has a special grind that really works. I think he posted a dyno sheet showing exactly what they made. Very impressive. Fitting these and doing the other work suggested will give you a big kick in the pants.
Old 07-13-2008, 11:58 AM
In the mean time, keep an eye out for a set of stock SC cams. I picked up a set of brand new ones on evil bay for $150 shipped. Then had John Doherty machine on the scavenge pump drive for another $150. $300 bucks, and didnt have to alter my stock cams (for when I put it all back to stock...if that ever happens)
John A.
1979 Porsche 930: 3.4L, SC cams, Twin plug, Leask WUR, Custom SSI turbo exhaust, Tial WG, K27HFS, and we can't forget the Zork (short lived depending on my homeowners assoc.)
05 Boxster S: For the Track.
06 Dodge Ram 2500 Power Wagon: Tow Vehicle
Old 07-13-2008, 01:18 PM
