Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
930 Slant Brake Duct Removal
Are the side ducts ahead of the rear wheel wells removable? I have to get at the thermostat at it will make life a lot easier if the ducts come off.
Thanks, Larry
Old 07-12-2008, 07:13 AM
DSPTurtle's Avatar
If it is a real slant, there should be screws covered with little black caps that you can unscrew and remove the duct from the inside of the fender.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-12-2008, 08:40 AM
Send a message via AIM to Chuck Jones
Can't you just take off the rear wheel and get to the thermostat on top? I just went and looked and I can see the thermostat even with the wheel on....or are you trying to change it out? It doesn't look like there's much clearance in there if you wanted to take it out due to the distance to the top of the wheel well...but if you're just after the wiring, it's readily accessible from inside the wheel well...
I just took out the entire unit to clean it up, and it wasn't a difficult job...a couple nuts on the bottom of the fan casing, several nuts on the bottom bracket, take off the two oil lines, and the whole unit comes out. Does yours still have the louvered stone guard on it?
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 07-12-2008, 10:44 AM
930gt-40r's Avatar
Are you talking about taking off the ducts or the vents? The vents are removable but the ducts are not.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 07-13-2008, 07:56 PM
Blaine Sellie's Avatar
Both the vents and ducts are removable. Sadly, to remove the torsion bars on a factory slant you must remove the ducts to get the needed clearance.....1/2 inch. BTDT
Blaine
1988 Porsche 930 Factory Slantnose- B&B Headers, GHL dual exhaust, K27-7200, Tial WG, B&B Intercooler, RSR Coilovers, Poly Bronze bushings. Dynoed at 373 hp/389 tq
1974 Porsche 914 2.0 Phoenix Red
2011 Porsche Panamera Turbo
Old 07-13-2008, 08:16 PM
930gt-40r's Avatar
What? Ive never seen that- but where is the seem? On my conversion, the ducts are solid to the body. Im glad you told me that because I never knew that, I always thought that they were integeral to the body.
Kris @ Tech9
86' 930/GT-40R Sold
Old 07-13-2008, 08:22 PM
I think the key word here is "conversion" as the "factory slant" is different. I almost took pictures of the removal 4 months ago when I upgraded to RSR coilovers....woulda,coulda,shoulda.......
Blaine
Old 07-13-2008, 08:32 PM
930gt-40r's Avatar
I know the conversion is diffrent...
Its ok because I am scrapping the conversion, steel ducts, fenders and all. I am eventually going to get the C2 turbo bumpers. The slant is ok, but not my cup of tea.
Kris @ Tech9
86' 930/GT-40R Sold
Old 07-14-2008, 04:21 AM
Forced Induction Junkie
WERK I's Avatar
The Special Wishes Slants built before MY 1987, had the brake ducts molded into the body. PITA, to but it mildly, getting to oil thermostat valve and torsion bars.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-14-2008, 08:07 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
