Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
DSPTurtle's Avatar
Ugh... Quick Fix???
Everytime I seem to get rolling on this rebuild I manage to break some completely obscure part that requires a Porsche special order (last night was the chain tensioner banjo bolt). I think the motor is beating me at this point...
So the latest SNAFU is the little ball joint piece broke off the throttle plate. It appears that this piece is press fit into the lever. Is there an alternative to buying a new lever? Get I get a ball joint that screws into the hole or am I just screwed? Anyone ever done this before or am I alone in this saga? JB Weld???
So close... yet so freaking far.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-15-2008, 05:08 PM
sudo apt-get purge 930
equality72521's Avatar
If you are good you can drill and tap a hole in the back of the ball joint and then bolt it back on. I've never done it but it seems reasonable for someone like me who's sitting behind a keyboard.
--clutch-monkey
Old 07-15-2008, 05:18 PM
BTW, what is that aluminum piece where the AC should be that I have circled in your pic? My car doesn't have that.
--clutch-monkey
Old 07-15-2008, 05:22 PM
DSPTurtle's Avatar
That is the big a$$ a/c mount that the compressor bolts to. Do you have a/c?
I had to take that big ba$tard back off to get the d@mn heater hose hooked up to the outlet. Yeah, this is like the world's most difficult puzzle only made more difficult by not actually having all the pieces in the dang box when you start the game.
Drill a hole in the back of the ball joint... you must be smoking a joint sitting there behind your keyboard
I actually thought about spot welding it but a replacement is like $20. It is more the embarrassment of having to call to order yet another part that I screwed up...
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-15-2008, 07:06 PM
Nah, that was another life.
I have AC but the mount doesn't look anything like yours. Mine is steel. At least yours weighs less.
--clutch-monkey
Old 07-15-2008, 07:19 PM
I would stick it back in the hole and weld or braze it back in place.
Old 07-15-2008, 08:04 PM
7.0:1 > 11.3:1
A couple days ago a guy brought me two of these balls which had threaded studs, he wanted them threaded to some other pitch. He got them from an auto parts store which carried retrofit gas struts.
Old 07-15-2008, 09:06 PM
DSPTurtle's Avatar
Two quick zaps with the MIG made everything better. I did order a new lever, but that will have to wait till the next time I pull the motor. BOV back on and the valve covers are next!!! If I am really good I will get the tranny bolted up tonight... nah, I am not that good
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-16-2008, 02:02 PM
I just finished putting mine back together tonight. I just got the bumper installed. Now I just need to do some final tuning.
--clutch-monkey
Old 07-16-2008, 05:33 PM
DSPTurtle's Avatar
You gonna show us a picture??? Just got the tranny mounted. Will post a thread once I get the starter installed but I had to take a beer break
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-16-2008, 06:02 PM
Well, I didn't take many pics after it was together. I took about 200 pics taking it apart though.
Partially done:
What it looks like normally:
--clutch-monkey
Old 07-16-2008, 06:13 PM
DSPTurtle's Avatar
Nice!!! What did you do to the BOV??? Did you polish it? BTW, did you remove your dizzy when you cleaned up your motor? I am betting against myself on having got that in correctly. I hope the dang thing will at least start up.
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-16-2008, 06:18 PM
DSPTurtle's Avatar
Since we are posting pics of what our cars "should" look like... here is mine before I defiled her
Actually all the good pics are on the other computer... this one is for my engine rebuild stuff. That poor bastard being towed away in the background in my old 914. This pic makes me happy and sad. (wow... that sounded queer. Gotta go do manly things in the garage now... what can I break next)
JB - BreitWerks
www.breitwerks.com
321-806-8664
Old 07-16-2008, 06:26 PM
I just used a soft wire wheel to polish it up. I wasn't looking for a mirror polish, just something to shine it up a bit. Yes, I pulled the dizzy. It's easy to do. Just make sure you're TDC on #1 cylinder, rotor pointing to the line on the dizzy body. I needed to replace the o-ring on it. I took it down to the case.
--clutch-monkey
Old 07-16-2008, 06:29 PM
karrerakid's Avatar
hey mark what exhaust is that ?
Old 08-12-2008, 08:18 PM
mark houghton's Avatar
Ditto....
Old 08-13-2008, 11:02 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
