jay71's Avatar
Hot Fuel Pump Relay
I was replacing a fuse in the front fusebox on my '86 930 today and I noticed that the fuel pump relay (the one closest to the cockpit) was pretty hot. I had just pulled into the garage after a drive that lasted about an hour. I haven't checked the fusebox before after running the car so I'm wondering if this is normal- or if I should be concerned. Other than the hot relay there aren't any issues with starting and the car runs great. If this isn't normal does it mean I've got a fuel pump that's ready to sh## the bed?
Jay
'86 930
'60 Land Rover Series II SWB
Old 07-16-2008, 07:05 PM
sudo apt-get purge 930
equality72521's Avatar
Shouldn't be hot, maybe slightly warm. Check all connections first. Makes sure everything is tight and clean. Bad connection=high resistance. High resistance=increased heat. Make sure all grounds are good and clean too. If all that is good then I would focus on a pump that may be pulling high current.
--clutch-monkey
Old 07-16-2008, 07:09 PM
Magpie's Avatar
Check connections for carboning up.
I've had blown fuel pump fuses in the past and found carbon build-up on the connections (including the relays) on my 78 and 79. These were the old style pre-spade type fuses btw. I sand off the carbon from the brass connections. I then carefully and slightly bend back the tangs holding the fuses; and take a thin exacto blade to carefully and slightly open up the pins on the relays. This has gotten me home more than once. I haven't had to use my spares yet. You want to save those towing trips for a real break down.
cheers,
mark
Old 07-19-2008, 07:12 PM
A fellow Pelacanite
NathanUK's Avatar
Some one has said there is a chemical you can apply that helps too. Do a search, I forget what it's called.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-20-2008, 08:54 AM
Stabilant is good for maintaining conductivity. http://www.stabilant.com/
--clutch-monkey
Old 07-20-2008, 09:01 AM
A fellow Pelacanite
NathanUK's Avatar
That's good stuff. But wasn't there a chemical that removes non conductive particles from conductive materials?
Old 07-21-2008, 09:51 AM
