Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
DSPTurtle's Avatar
Rite of Passage
So it is midnight yet again...
Today was the day of duplicating efforts. I learned the intricacies of 930 jig saw puzzle.
A few things that were not in any of the books...
1. Don't install the #1-3 header until AFTER you install the crossover pipe or else you will have to remove the just installed header so that you can install the crossover pipe... at least for the stock euro exhaust (I have no idea about others)
2. Don't install the the turbo and associated plumbing until AFTER you have the drip tank properly situated or else you will end up removing the just intalled turbo and associated tubing, get everything situated and try again.
3. Don't trust the guy at Advanced Discount Auto Parts to sell you a pump/siphon to fill your tranny unless you want to get about 2/3 of a quart in your hair, all over your clothes and basically everywhere else (this is the same guy that told me that all I should need to do is remove the shift lever cover and pour the fluid down the open hole )
4. Don't let the clutch spring pop you in the head while you spend two hours trying to figure out how to get the damn thing compressed so you can install it only to find out all you need to do is pull the arm forward, put in the spring and pop the arm back... that takes about 30 seconds (I vividly remembered a quote from Atlas Shrugged, "If A does not appear to equal A, check your premise". In other words, none of the ***** is that hard... if it appears to be hard, go inside, drink and beer, go back outside and realize you were overthinking it )
Other then that and the gash on my forehead that almost knocked me cold from the bumper mounting points everything else seemed to bolt back together. CV joints are torqued, shift rod is screwed together (although I need to splice a new connector on the back-up switch and speedometer, and tranny is filled with Mobil 1 gear oil for break in so I don't leak fancy Swepco all over the floor.
I forgot what the car looks like with a muffler...
In case anyone is wondering what the hel! I am talking about in #2 above, here is a picture of the little b@stard for posterity...
And finally, I had to go searching for the IC as I could not remember where I had stored it three months ago
Looks like I should be putting spark to fuel tomorrow morning sometime. I will leave the bumper off for the gas leak checks and then take it for a ride. Maybe even drive it to Orlando in the afternoon since my wife wants me to take her to Disney... yeah right, like everything is going to go that smoothly
Anything I should double check before I hit the key???
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-18-2008, 08:34 PM
Hirevtuner's Avatar
Looks like your having fun. I always turn on the fuel pump and look for leaks before hitting the starter as I had a fire once and now I'm paranoid.
1981 411 rwhp, Ruf intercooler, 964 cams, Turbo Kraft injector blocks, Extrude honed intake, 7006 Turbo, Tial wastegate, RarlyL8 exhaust, MSD6al
Old 07-18-2008, 08:43 PM
A fellow Pelacanite
NathanUK's Avatar
I had great difficulty getting out my turbo due to the stock drip tank. I can certainly appreciate how tricky it is to get them back in. I have changed to GHL headers so I won't have that problem anymore.
Nobody else seemed to think it was difficult...
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-19-2008, 02:07 AM
Blackbird Pilot
Reaper930's Avatar
Looks good, you get a Red Stripe for effort its the only grade you can drink
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 07-19-2008, 04:57 AM
Dai Dai is offline
You are a very brave man. I truly enjoyed your thread and thanks for taking time to share your story with us. You had me laughed out loud a few time. :-)
Old 07-19-2008, 08:29 AM
