Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
e p slick's Avatar
Fuel Distributer initial settings
Just put different fuel dist (USA) on my 79 930 as I am still waiting for stainless gasket for my old unit (Euro). My "New" fuel distributer is a 88 model but, by all visual considerations, it seems as if it should work. Everything lines up mechanically. My problem is that when I build system pressure and depress mixture adjuster I can hear system squeak and screech like expected. Turn on starter circuit and engine comes to life but then quits once initial fuel squirt is used up. Unfortunately I have most likely turned mixture adjuster screw out of its proper range.Curious to know if there is a baseline number per fuel system benchtop set-up in order to keep engine running so I can adjust AF + idle and get back to a starting point. Appreciate any response. EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 07-20-2008, 08:21 AM
Acceleration Junkie
If the engine fires/runs briefly, then shuts down, likely too lean. Fuel to fire initially is likely being supplied by the 7th injector and not the fuel head.
Don't know about benchtop set-up. Try turning enrichment screw 1/2 turn clockwise (remember, Right is Rich, Left is Lean), see if the engine will fire/run. Repeat till engine will stay lit so you can fine tune.
Old 07-20-2008, 08:43 AM
e p slick's Avatar
question
DISREGARD QUESTION - I have found the answer to my question in a tech article.
EPS
Old 07-21-2008, 12:16 PM
A fellow Pelacanite
NathanUK's Avatar
Link?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-22-2008, 09:03 AM
e p slick's Avatar
Nathan in Old Blighty
Link: Oddly enough I found it on page 262 - Mixture control - line references 65 through 71 - Haynes, yes, Haynes PORSCHE 911 Repair Manual - ISBN 1 85010 698 3
Cheers
Old 07-22-2008, 01:07 PM
A fellow Pelacanite
NathanUK's Avatar
Eldon in Uncle Sam
I do have that manual
Old 07-23-2008, 09:50 AM
