Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
SC cams Timing?
Hi I wounder if any one can recommend how I should set the timing
Have a 930 engine 1976 with SC cam. original should set 1mm. but with this cam should i go for 1,4mm. or more??
the engine is now 3.2 liter and have JE pistons and ported heads etc.
big turbo.
Old 07-21-2008, 05:17 AM
"I wuz the liquor..."
sand_man's Avatar
I went 1.65 with my 3.4L Turbo and SC cams. When my parts were at the machinist being measured and such, his recommendation based on the mock up he did to check for valve to piston interference was 1.70. Keep in mind this was for *MY* engine...YMMV.
-jeff
Old 07-21-2008, 06:05 AM
sand_man's Avatar
Looks nice, BTW...
-jeff
Old 07-21-2008, 06:06 AM
this is what the car looks like!
Old 07-21-2008, 06:39 AM
Forced Induction Junkie
WERK I's Avatar
+1
You reach the point of diminishing returns after that. With that beautiful 3.0 your building, advancing the cams to that value will help your low end torque. With larger port 3.2 heads, the port velocity is going to drop a ton, but the higher compression pistons should compensate quite nicely.
As Sand_man states, always check valve to piston clearance when using new pistons and changes in valve timing.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 07-21-2008, 07:04 AM
The engine is now 3.2 liter 98mm piston and the heads are ported to 38mm.
What you mean is that 1.mm is good and to go over that is not good ?
I will measure the clear ens!
Old 07-21-2008, 07:35 AM
WERK I's Avatar
It's not going over 1.6-1.7 is bad, it's that there is very little to be gained by going over that value......except maybe valves kissing the pistons. When you advance the cams, you're moving the entire VE curve to the left and it provides you a little more low end torque with little sacrifice on the top end RPM range.
Dave
Old 07-21-2008, 07:49 AM
Wo ist die Rennstrecke?
DonE's Avatar
+1
You might be better off going to a different (aka, custom) cam.
Old 07-22-2008, 04:47 PM
