Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
parasailsam's Avatar
High Idle on turbo conversion
Need some help.
I have converted my 3.0 to a oem turbo and cant get it to idle down any where close to 1 grand.
I bought a oem 930 take off and have had it installed by my local Porsche mechanic and he cant get it to idle right.
Any thoughts?
Aside from finding a new mechanic.......
Thanks,
Sam
'77 Ice Green 911s Targa that's almost a 930
Old 07-21-2008, 06:29 AM
A fellow Pelacanite
NathanUK's Avatar
Post some pics, maybe something is not hooked up right.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-21-2008, 10:23 AM
beepbeep's Avatar
It's fairy simple: as long as it's tight after throttle, idle goes down.
So you have a leak either across the throttle or after the throttle. Cracked phenolic intake stacks are common, as are leaky intake/head gaskets. Big brass throttle bypass valve can be removed and hoses plugged.
Pressurize whole system with shop air and check for leaks. Use max 1.0 bar.
Thank you for your time,
Old 07-21-2008, 11:20 AM
Crotchety Old Bastard
RarlyL8's Avatar
Electricity to the AAR?
Old 07-21-2008, 12:00 PM
Smart quod bastardus
fredmeister's Avatar
I second that.......make sure the AAR is actually being heated with electricity. Otherwise it will not close down the internal bypass valve.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-21-2008, 12:42 PM
Aar
Checking on the air valve, I'll let you guys know soon.
Thanks,
Sam
Old 07-21-2008, 06:02 PM
ongoing
The aar valve is said to be good.
My mechanic say it needs further tweaking in the fuel injection sys to make it right.
Thoughts?
Thanks guys
Old 07-22-2008, 12:44 PM
