87turbo's Avatar
Tires for stock 16" rims
Hello,
I just replaced a set of Bridgestone Potenza tires with Sumitomo HTR z's after blowing out a rear tire (one of the bridgestones). The car is driving/handling pretty bad now, and I've had it looked at for alignment/balance. The garage put another set of tires from another 930 on it, and found that it was driving fine that way. But with the new tires on, it handles terribly. Garage feels that it is the tires.
Has anyone else tried these tires? Looking at Tirerack, there appears to be very limited options - these, the Fuzion ZRi, and the Hankook Ventus R-S2. Has anyone tried either of the other two brands?
Thanks,
Eric
Old 08-04-2008, 12:26 PM
F350Lawman's Avatar
Hankook RS2 is a good choice. I ahd them and rand them on the street for over a year and 2 x at the track. Not bad on the track and good on the street.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 08-05-2008, 07:06 AM
87turbo's Avatar
Thanks - I'll give them a try. Every time I think I've got the car sorted out, something else pops up! But I think I'm close now...
Old 08-05-2008, 09:48 AM
wcc wcc is offline
wcc's Avatar
Are you sure you didn't damage (bend) your rim when you had your blowout?
Maybe your tires are out dated or you got a defective one?
I've been running those same tires for a few years now and have no complaints.
Bill
Old 08-05-2008, 03:16 PM
87turbo's Avatar
Good points - I had a race shop put the tires on the wheels, balance, and check alignment. I didn't specifically ask them to look at the rear wheel though. A friend said he had a similar experience with a set of tires and that it took a couple thousand miles before they ran right. The car is going back into the shop again next week, so I'll ask them to double check the rim.
Thanks,
eric
Old 08-06-2008, 06:38 PM
I have a set of Sumis on the 930 right now = no problems at all.
Old 08-08-2008, 07:43 AM
Cowtown10's Avatar
Just put Sumi's on mine last week. 18x225 and 18x295. I like them a lot and it doesnt hurt they are way less$$$ than Michelins. No problems
Q
2002 996TT
1984 930 Turbo (gone and missed)
Old 08-08-2008, 08:08 AM
Smart quod bastardus
fredmeister's Avatar
Chances are the rim is bent.
Bridgestone are good tires. I use them on my 79 930, no problems.
Have them run the rim on the balance machine by itself and see if it has run out....in other words is bent.
Or check the tires for out of roundness as well.....could be a bad batch.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 08-08-2008, 10:04 AM
87turbo's Avatar
Taking it back in on the 18th - thanks for the ideas which I'll pass along. I've been driving the car everyday, seems to be staying about the same. It is definitely better now than when I had sumi's on the back, bridgestones on the front. Bridgestones aren't even listed at tirerack in my rear size any more.
Thanks again,
eric
Old 08-08-2008, 03:43 PM
87turbo's Avatar
Bent rims the whole way around... I think 2 were far enough off the balancing machine couldn't come up with compensation. So now the wheels are headed to another shop to get looked at. I don't off-road, but I do drive the DC beltway...
Thanks for the ideas/suggestions!
Eric
Old 08-23-2008, 08:22 AM
spence88mph's Avatar
I'm trying to work out what to put on now too, I was thinking of just getting some 17 or 18 inch rims but I just love the look of the fuches. Anyone else have any ideas, how about Continentals?
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 08-23-2008, 05:39 PM
these contisports come in the correct sizes we need and I have heard good things, anyone with experience?
http://www.tyres4u.com.au/brandselector_doc-contiprodcsc_img-cp_show.aspx
'89 911 M491+Turbo
'89 944 Turbo
'88 928S4
'18 C63S Coupe
Old 08-23-2008, 05:49 PM
