BOV opens up too early...
As the title says, I find mine opens up wwaaayyyy too early - as soon as I do a gentle lift or maybe even a slight pause on throttle then I'd hear the BOV wide open.
I am using a Tial 50mm one, and it vents to atmosphere. Would a stiffer spring help here? And, how would one choose which spring to get? I followed Tial's recommendation, but its really opening too often/soon IMHO.
thanks!
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 08-10-2008, 10:43 PM
Crotchety Old Bastard
RarlyL8's Avatar
The BOV/recirculation valve should be open whenever the engine is not under load.
Old 08-11-2008, 12:37 PM
Understand that... but what I'd like to see is whether there is a way so that the BOV would remain closed longer when the engine load decreases slightly.
Right now, as soon as the load is not increasing, the BOV seems to open right away. Hence, throttle response really suffers due to boost loss in transient throttle situations.
Old 08-11-2008, 03:00 PM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
With aftermarket BOVs you can install different springs.
BOV opens when:
TB press < (I.C. press + spring press)
So, reduce spring, and valve will open sooner, and vice-versa. With more spring you'll have more run-on tendency methinks, and I'd guess a more abrupt lurch when it finally does open. I've never driven a turbo car w/o BOV, but I did ride a GSX-R 1000 with a turbo kit under development. It did not have a BOV and accordingly had an UNNERVING run-on after the throttle was shut.
With my EFI I'm definitely going to experiment with a mechanical (spring valve) Boost Control, and this tickles my thinker into experimenting with different BOV springs too.
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 08-11-2008, 03:48 PM
A fellow Pelacanite
NathanUK's Avatar
Just to add, they also do shims to fine tune between the different springs.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-12-2008, 11:10 AM
