LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
935TURBO's Avatar
Thanks to you all for the compliments.............and I came on the road...legal street/motorway......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 09-22-2010, 11:15 AM
935TURBO's Avatar
Thanks Jeremy for this nice video........
Old 09-27-2010, 11:57 AM
935TURBO's Avatar
Back on my TT engine project........
The base of the project is my original engine, the one I've got on my car when I bought it....a 930 turbo S motor.
I got 3.5 Mahle pistons/cylinders and I had to machine the engine block to fit the cylinders.....diameter 100mm
and somme more improvement to help air flow inside the block....
I also got 962 heads from Paul Weir since 4 years.....chambers and outlets have been polished and now, I have to find a solution to adapt heads on cylinders with or without gaskets.....I need some advice......
One of my thoughts is the following one.......
Does someone have some experience and feedback with that kind of assembly...?.....and with gaskets or not....?
P.S.: basic ratio for the pistons/cylinders is 7:1 and of course, it will change a little bit if I machine the cylinders heads.....but, as it's a turbo engine......
Old 10-24-2010, 07:30 AM
02fly's Avatar
Wow amazing car
Old 10-24-2010, 12:49 PM
935TURBO's Avatar
Thanks O2fly.....
Finally, I'll probably go that way.(thanks GJF... ) wich seems the most reliable....
Old 10-25-2010, 04:33 AM
I would rather be driving
jpnovak's Avatar
Serge,
Great car. The heads look to be cut for a retaining ring. This is commonly called a flame ring. It helps seal the combustion chamber against leakage when high boost pressure leads to intense combustion pressure.
I suggest you find a machine shop that can cut the cylinder mating surfaces to match. This usually requires custom flame rings to be cut at the same time. This is a process exactly as you illustrated.
You might want to check with Mike at MBEnginneering in the UK. He is a contributor on this board. He would be relatively local and capable of the machine work.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 10-25-2010, 09:06 AM
935TURBO's Avatar
May be, I'll have some more work in the very next future......
I don't know what happened at 11'28"..........
Old 04-04-2011, 05:32 AM
tj930's Avatar
Nice video. I've been around Le Mans.. (On my PlayStation3 )
You certainly are a 'gentleman driver', Serge.. I wouldn't have put up with that Boxster and White 911S for as long as you did! (I'd have shown them my HUGE, over-sized, rear wing.. Getting smaller and smaller )
Anyway, hope you got the 935 going again..
Old 04-04-2011, 01:15 PM
tj930's Avatar
"C'est bon! J'adore votre voiture"
Serge, I've watched your videos. Your car rouge, she is magnificent.
But you make James May ("Captain Slow") look like Ayrton Senna - please, show me a video where the engine goes above 3,000RPM!
Old 04-04-2011, 01:37 PM
935TURBO's Avatar
Thumbs down
We discovered a 1" hole on the engine case....close to the meedle cylinder base....may be due to a rod screw......oh....s... !
Old 04-04-2011, 08:29 PM
proffighter's Avatar
Something like that I thought after watching your vid
Roland
930 Turbo '81 Too many modifications to list
Old 04-04-2011, 11:57 PM
Very very nicely finished! cool .I want one ...lol...
Cheapest WOW Gold WoW Gold Cheap RS Gold
Old 04-05-2011, 02:05 AM
935TURBO's Avatar
Old 04-06-2011, 12:33 PM
Lurkasaurus
turbocarrera's Avatar
WTF was that!?! You said something about a rod bolt? Man I'm sorry. That sucks!
Tony '77 930
"Objects in mirror are losing"
"Oh cock..." - James May
Old 04-06-2011, 01:41 PM
Turbofrog
smurfbus's Avatar
That is really odd! The case seems repairable but the hole is so clean it's almost as from a bullet.
Old 04-06-2011, 08:41 PM
MikeD930's Avatar
Oh man...I'll say it's a loose/broken rod bolt punching through the case. What a stinkin' bummer! I hope the damage is minimal.
MikeD
'87 930
Old 04-07-2011, 02:15 AM
935TURBO's Avatar
Originally Posted by MikeD94 View Post
......./...I hope the damage is minimal.
.....I'm looking around to find a complete engine....it'll be easyer to be ok for the track season at my French club.....
Old 04-09-2011, 02:05 AM
935TURBO's Avatar
Is that looking normal.....?......
Old 06-20-2011, 01:38 PM
don't ya hate it when that happens..
Old 06-20-2011, 01:49 PM
E-man930's Avatar
very sad...
Old 06-20-2011, 02:03 PM
