Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
Fabspeed muffler extension discolored
I recently installed a new single outlet stainless steel Fabspeed muffler system on my 1986 930. I'd like to know if the discoloration of the outlet pipes after the muffler extending to the tip should have discolored as they haven (see pix). The muffler remains shiny and bright but the stainless steel extensions have dramatically discolored - the stainless has discolored to almost a "rusty" look. I have contacted the distributor and they have indicated that this is "normal". Any thoughts??
Thanks, Goosh
Old 09-01-2008, 08:44 AM
David's Avatar
Perfectly normal.
2014 Cayman S
2011 Cayenne Turbo
Old 09-01-2008, 09:33 AM
Crotchety Old Bastard
RarlyL8's Avatar
Plished stainless will discolor with heat; the rate and darkness of the bronze being directly proportional to time and temperature.
Here are some pictures of newly built exhaust systems, one brushed and one buffed. The last picture is how my prototype brushed system looked after a year.
Old 09-01-2008, 11:34 AM
A fellow Pelacanite
NathanUK's Avatar
But why did the tailpipe discolour and not the actual muffler?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-01-2008, 12:00 PM
RarlyL8's Avatar
The tailpipe is just an unshielded tube of metal so it sees all of the heat. My muffler bodies packed with sound deadening material discolor at a much slower rate due to the insulating effect. The neck of the muffler, right off the turbo, turns a deep bronse/brown fairly quickly.
Old 09-01-2008, 01:43 PM
Send a message via AIM to Chuck Jones
They polish back up if it bothers you. I just used some of those abrasive sticks on a bench grinder fitted with a couple cloth polishing wheels and brought it back to it's original glory. It could also be that the pipe is not made of the same quality or stainless steel compound that the rest of the exhaust is....so it colors more quickly. Since is comes off with just the unscrewing of a band clamp, I've polished mine a number of times...but only down to where it shows. You can do the polishing in about 10 minutes with the wheel and the white and red abrasive sticks.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 09-01-2008, 02:23 PM
Macht Schnell
les_garten's Avatar
Hmmm, I've always liked the way SS develops a Patina. It kinda looks like Titanium to me when it gets "straw colored". When I look at a pipe set like that, it's obvious that it's SS. The Fabspeed is so pretty though, I can understand why you "wish" it would stay like that.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 09-01-2008, 03:15 PM
Me like track days
Craig 930 RS's Avatar
His is definitely more than just a discolor - it certainly looks to be more of a differential between the two than I have seen -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-02-2008, 08:24 AM
RarlyL8's Avatar
Like Chuck said you can re-polish it back to where it was.
Old 09-02-2008, 08:59 AM
My educated guess is a difference in alloy's in the stainless as to why such a huge difference. probably has allot to do with where the raw materials were sourced and if from 2 different mills or different specs(I tend to think is the case) the tail pipe/tube is probably ordered and then polished where as the can of the muffler probably comes #7 finish and then after welding that assembly is probably electro polished which will slow the coloring process as is closes the pours of the metal chemically
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 09-02-2008, 10:18 AM
The tips of my B&B exhaust were almost a gold color when I picked up my car. I used some Flitz metal polish on them and the look great again. I have to polish them about every third wash depending on how much rain I drive in.
http://www.autogeek.net/flmepopare1o.html
1987 GP White 930
1977 Ford Bronco
Old 09-02-2008, 11:10 AM
A fellow Pelacanite
NathanUK's Avatar
My unknown SS muffler is very dark.
Old 09-02-2008, 12:23 PM
Thanks all for the feedback - my extensions discolored within 3 or 4 days of installation - I had assumed that the stainless steel finish would retain its original luster for quite some time. I tend to agree with mb911 that the two types of stainless steel are different grades of metal and/or finished differently. I am disappointed that Fabspeed did not divulge the potential for discoloration prior to my purchase. The sound is great ... the look is bleak!
Thanks again!!
Goosh
Old 09-02-2008, 06:52 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
