930 clutch options?
Hi .... the other day at the stoplight while holding the cltch down , I heard (and felt) a crunch in the pedal. Now the pedal only returns half way and the clutch disengages 3/4 of the way down.
I cant seem to be able to get in where the cable terminates up front but I suspect the problem in at the clutch arm to presure-plate/TO-bearing. Clutch slips really bad now as well. Hopefully it is something other than replacing everything.
Anywho ... now that I mst likely will pull hte engine to address this clutch issue I think I should probably just replace the clutch, pressure plate and throwout bearing.
I was wondering about clutch options? This car is moslty stock except for bolt on mods so high-hp setup is not necessary. Any suggstions on aftermarket set-ups or are the stock pieces the way to go?
thanks for any help,
Oskar
Old 09-02-2008, 03:45 PM
930turbo's Avatar
It sounds like a broken diaphragm spring (pressure plate). No clamping force. Is the pedal easier to push down since the crunch?
'77 930 turbo Garretson I/C 1 BAR spring, (2) '82 Triumph Bonneville Royal Wedding Edition
Past rides: '74 914 1.9 liter twin plugged track car, '83 928S, '87 924S, '75 911S w '78 ROW 3.0, '72 911T, '70 911T and various other insignificant domestic examples. Happiness is a grey tailpipe! Turbo lag......it's worth the wait!
Old 09-02-2008, 05:57 PM
Max Sluiter
Flieger's Avatar
You checked the roll pin in the pedal cluster shaft below the footboard?
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 09-02-2008, 07:19 PM
A fellow Pelacanite
NathanUK's Avatar
Use the early spring centered disc if you do need to replace the disc.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-02-2008, 11:14 PM
resident samsquamch
sand_man's Avatar
Before you make any assumptions and pull the tranny/engine, you really need to verify that something else isn't going on. Rule out the other things like:
-Fraying clutch cable
-Improperly adjusted clutch cable
-Worn, cracked, or dislodged "Omega" return spring on the bottom of the tranny
-Worn pedal bushings
-Broken pedal roll pin
-Cracked pedal cluster shaft - often the shaft the roll pin fits into, cracks right at the pin hole
To inspect the areas around the pedal cluster, it is often easier to gain access with the center console removed...and obviously the foot board that hides the pedal assembly.
There is no point in replacing expensive clutch components (pressure plate, disc, T/O bearing, pilot bearing, flywheel resurface/replacement, main seal) only to find out that your pedal still isn't right.
-jeff
Old 09-03-2008, 04:53 AM
resident samsquamch
sand_man's Avatar
As for clutch ideas, the factory pressure plate weighs a ton...it's a freaking anchor!!!!! I wish that when I did my clutch job, I would have taken another path. These folks have some good ideas for "lighter weight" clutch parts. Their prices are a tad high, but it's a good starting point for research:
http://www.patrickmotorsports.com/parts/7/6/12/
I'm planning to run the KEP Stage 1 PP with the stock spring centered disc when I finally "do-over" my clutch...
-jeff
Old 09-03-2008, 05:03 AM
resident samsquamch
sand_man's Avatar
One other thing to add, if it does end up being your clutch, when you have your engine/tranny out and apart, a few other things to check for wear are the T/O bearing guide tube in the center of the tranny bell housing, the clutch fork shaft, and the fork itself. Yeah, yeah, I know it's no biggie to pull the engine, but I hate going back in...
-jeff
Old 09-03-2008, 05:12 AM
David's Avatar
I'd stay away from Centerforce. When I get off my a$$, I'll be putting a KEP in mine.
2014 Cayman S
2011 Cayenne Turbo
Old 09-03-2008, 07:47 AM
Thanks , will check on these things. KEP pressure plate looks like the way to go.
Old 09-03-2008, 08:59 AM
fyi my clutch was real stiff.replaced clutch cable pedal cluster with no luck.pulled moter replced disc and TO motor back in same thing pulled motor 2nd time found clutch fork had hair line crack on one side this would bind the TO on the shaft relaced fork problem solved
Old 10-06-2008, 08:36 PM
resident samsquamch
sand_man's Avatar
This is exactly what I'm expecting to find when I get ready to do mine.
-jeff
Old 10-07-2008, 05:05 AM
