Twin Plug Valve Cover Gaskets
For those of you with your 3.3L's twin plugged, are you using the stock valve cover gaskets?
Thanks,
Bill
Old 09-04-2008, 09:40 AM
rsrmike's Avatar
Yes, it helps to cut a small notch for the #3 & #4 plug connector, but not essential, it just helps putting the plug connectors back on the first time since new gaskets
Just look at your old ones when you get them off, you'll see most likely
Professional Overcomplicator
Old 09-04-2008, 09:49 AM
rsrmike's Avatar
The normal green gaskets w/ small grey bead of sealer printed on seem to work just fine.
Old 09-04-2008, 09:50 AM
Thanks Mike, I need to order another set. I have the really nice billet twin plug valve covers from IA, but it looks like they are leaking from around the stud holes.
I am going to order a set from Pelican and reinstall them.
Bill
Old 09-04-2008, 09:53 AM
resident samsquamch
sand_man's Avatar
I run the silicone re-usable ones, purchased from our host...
EDIT: of course I'm running the OEM 930 covers that were cut for extra plugs...not the IA ones, or anything 964 based.
-jeff
Old 09-04-2008, 10:06 AM
my OEM 930 covers were cut by a blind person using an ultra dull hole saw, or maybe a rock and a bigger rock, so I had to get something new.
Old 09-04-2008, 10:30 AM
A fellow Pelacanite
NathanUK's Avatar
Are the silicone ones any good?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-04-2008, 10:35 AM
resident samsquamch
sand_man's Avatar
Have had them on and off too many times to count, and no leaks...they've paid for themselves.
-jeff
Old 09-04-2008, 10:44 AM
David's Avatar
I'm having good luck with drilled stock 930 covers and stock type gaskets.
Old 09-04-2008, 12:51 PM
rsrmike's Avatar
Bill
No sweat, be sure to get new aluminum washers and lock nuts whichever route you take. I've never used the silicone gaskets but that sounds like a neat way to go too. Enjoy!
Mike
Old 09-05-2008, 07:14 AM
Macht Schnell
les_garten's Avatar
I've always been amazed at their propensity to leak around those studs?
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 09-05-2008, 08:19 AM
resident samsquamch
sand_man's Avatar
The silicone gaskets, fit tightly/snugly around the cover studs and helps prevent the leaks. Please don't throw me under the bus, but I've also re-used the same nylocs/washers four times now...still no leaks. I also install my covers on the "loose" side. I go around with a short handled ratchet and get all of the nylocs just barely snug to the covers, and then go around one more time hitting each nut another quarter turn or so, in a criss-cross pattern. YMMV.
-jeff
Old 09-05-2008, 08:30 AM
You don't torque them down to anything light?
Old 09-05-2008, 09:07 AM
resident samsquamch
sand_man's Avatar
Don't get me wrong, they are snug. By the time I'm done, the orangish colored silicone gaskets are just barely squeezing out.
-jeff
Old 09-05-2008, 09:16 AM
Thanks.
I did order all new nuts and washers. I guess the problem in the past has been the gasket has torn around the studs. I will try a new set of gaskets with the silicon bead on the bottom (already have them ordered from PP), and if I am still having issues, I'll try the thicker orange ones that you have.
On a side note, I'm looking forward to this job, as I can use the lift, and not be on my back...yeeeah.
Bill
Old 09-05-2008, 09:18 AM
resident samsquamch
sand_man's Avatar
I'd be anxious to use the lift as well, but if you jack up one side at a time, you minimize any of that "black gold...texas tea" from leaking out when you remove the lowers.
-jeff
Old 09-05-2008, 09:22 AM
I know, I thought about that as well, but its time for an oil change anyway....
Old 09-05-2008, 09:24 AM
A930Rocket's Avatar
I'm surprised how often they leak as well. Seems to be hit or miss and no matter if I use new or re-use the nylocks and washers.
I've got to powder coat my lowers again and when I do, I'll go with the silicone gaskets/new nylocks/etc.
Old 09-05-2008, 10:22 AM
Macht Schnell
les_garten's Avatar
If you get "Torquey" on the silicone gaskets, the Valve covers cut them up.
Old 09-05-2008, 01:08 PM
rsrmike's Avatar
Sounds like that is the only drawback to the silicone,
If only someone molded thin bushings into the gaskets, giving you a "stop point" for the valve cover yet retaining the proper compression of the silicone...
Old 09-05-2008, 01:16 PM
