-   -   Identify Injector connections CIS (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/429033-identify-injector-connections-cis.html)
zcoker 09-06-2008 05:36 PM
Hey all, I have a 81 euro 930. Behind the CIS housing are three (3) injector connections but I only found two plugs. I think the connection on top of the CIS housing is some form of fuel shut off? There is a cold start valve to the right of that in the center of the housing and then below the cold start valve in the center of the manifold, there is a regular bosch injector- does this sound right? Any help in identifying these parts would be helpful. Also, the plugs were unplugged so I have no idea were they connect. Everything looks factory, as far as I can tell.
NathanUK 09-07-2008 01:56 AM
Do a search, I've posted all the correct colours before and my memory is bad...
NathanUK 09-07-2008 08:01 AM
Green connector goes to the CIS.
