Certified User
billjam's Avatar
Originally Posted by WERK-I View Post
Billjam,
Maybe you already know this, but have you thought about what you are using for the down pipe between the turbo and the IC? I believe the 3dlz down pipe will not work. If you already mentioned this in your thread, I apologize.
Yes I am aware of this.
I already have a up-pipe that has been cut down in length (at the top end) to accommodate a B6 IC so I intend to cut off the 3LDZ connection at the bottom and use silicon hose between turbo and pipe.
I haven't actually got things assembled far enough to be able to work out the final details, but that is the general plan. Boy, is this so much easier on an engine stand!!
Old 09-17-2008, 06:16 PM
