Air/Oil Separator Mounting/Need
I am getting ready to put this back into the car with new hoses. Does anyone have pictures of how the unit mounts?
I am also considering just removing it and running the crankcase breather pipe to the oil tank directly. Any thoughts or opinions on doing so? Any help is appreciated, thanks.
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
We're fans of using the factory AOS if you have an oil tank with drain-back port.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
this bit?
![]() ![]() Sorry - came out sideways even tho I rotated them before posting. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
Yep, that's it Alan. I think I may have lost a bracket or something because I cant figure out how it mounts to the side of the engine bay.
The bottom pic shows the mounts - two bolts on a bracket - I haven't removed mine. I can try and take more pics of the hose connections if you need.
Alan
Yes, all the engines have some blow by, may as well separate it efficiently and route the oil back to the tank in liquid form. It leaves almost no oil vapor in the breather hoses.
Cool thanks all.
I think I am missing a bracket to get it mounted to inner fender. Does it just attach to the oil tank mounting studs?
Yes, just a simple strip of metal with a 90deg twist in it, fits on forward tank stud.
