Jerry S's Avatar
Busted thermostat Now what ?
The casing of my thermostat broke while trying to remove the oil lines during a header install job. What are my f___ing options now ? What is the cost of a new OEM? Are there good aftermarket options ?
Mark
TURBO = Free Power
Old 09-19-2008, 04:44 PM
Jerry S's Avatar
Unhappy
I need the external thermostat which is mounted in the right rear wheel well. Where is a good source for this part ?
Mark
TURBO = Free Power
Old 09-20-2008, 08:41 AM
Uhh, Porsche breakers for a used one or our host for a new factory replacement?
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=ENGoil&page=3&bookmark=11&part_number=930-107-017-00-M260
The Mocal replacement is also available from our host, with or without cooler upgrades: http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGoil_pg3.htm
As well as Dr. Timmins: http://www.instant-g.com/Products/911Mocal/index.html
'77 S with '78 930 power and a few other things.
Old 09-20-2008, 09:40 AM
You could ask Tom, he is a member here. He had what I needed.
tom1394racing
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 09-20-2008, 09:43 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Buy a new one. You'd be taking chances with a used one.
The Mocal really wouldn't work because of the -12 fittings and the way the fittings are set up. If you were doing an aftermarket setup, it would work.
Old 09-20-2008, 06:08 PM
Jerry S's Avatar
I just received another kick to the nards while trying to pull the lines off which go to the cooler. They twisted and kinked even with a second wrench on it for . Added expense here we go. Does anyone here have experience using alternative oil lines as opposed to the factory 'hard' lines. I am thinking of going with a stainless braid. Are they pricey ?
Mark
TURBO = Free Power
Old 09-20-2008, 09:04 PM
A fellow Pelacanite
NathanUK's Avatar
They won't dissipate heat like the stock lines do, which isn't good.
They must be a lot cheaper than the factory parts though.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-21-2008, 03:03 AM
A930Rocket's Avatar
They can get pricey. Go with -16 and price it out. Maybe you can find some new ones or even repair your old ones. Didn't someone weld in a copper section to fix theirs?
As suggested, the stock lines make good heat sinks, so if you go with stainless steel, make sure your oil coolers are good or add another.
Old 09-21-2008, 08:20 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Nathan you are correct on the disipation. But I think it wouldn't matter with the rocker cover. I made new ones using 4130 but DOM mild steel would be easier. You could go to any hydralic supply shop and they can make you what you need and would be far cheaper than braided lines and anodized hose ends. plus they would be far more durable.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 09-21-2008, 08:45 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Also I use the Mocal thermostat with -16 ends it works very well and have never had a problem with it 5-6 years now. Try www.batinc.net they are pretty reliable and have good service.
Old 09-21-2008, 08:49 AM
Jerry S's Avatar
Do the braided stainless hoses not work well for heat dissipation ? I purchased the B & B Headers and in the kit comes flexible stainless pipes which look great .
Mark
TURBO = Free Power
Old 09-21-2008, 09:50 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
You would not be able to tell the 5 degree difference between the two. Thousands or race cars use braided lines for 20+ years with zero heat issues. The oil cooler is designed for heat disipation not the oil lines. Even those extruded aluminum oil lines that connect from the oil tank to the engine won't net you any readable results. Don't lose any sleep over oil line heat disipation! Be more worried about the volume of oil flow. -16 is the smallest I would even consider for a Porsche aircooled oil line.
Old 09-21-2008, 10:20 AM
