resident samsquamch
sand_man's Avatar
Originally Posted by Alan L View Post
Sometimes life sucks. But I still find them more consistent than women.
Regards
Alan
No truer words have been spoken...
-jeff
Old 11-21-2008, 02:46 AM
Forced Induction Junkie
WERK I's Avatar
Don,
Were there any other cylinders that had bad valves/guides or was #3 the only one?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 11-21-2008, 04:54 AM
Wo ist die Rennstrecke?
DonE's Avatar
4 of 6 heads had trashed guides, both intake and exhaust. The valve stems were trashed as well but they sealed just fine on their seats - compression and leakdown tests were all good. The only explanation given was bad guide material.
Old 11-21-2008, 04:49 PM
Will program for food
ghnat's Avatar
Don,
Any updates?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 12-18-2008, 06:07 PM
DonE's Avatar
Picking up the heads in FL while on vacation next week. I should have it back together around new years day. Let's see if I can top more than 5000 miles before I take it out again.
Old 12-18-2008, 06:20 PM
ghnat's Avatar
What part of FL? I'll be in Tampa and Hernando next week...
I'll need some head work as well. Maybe you can give me a contact???
Has the studying finished?
Greg Hnat
98 Jeep Cherokee
Old 12-18-2008, 06:25 PM
DonE's Avatar
Bill at Xtreme Cylinder Heads in Palm City FL. One more test in early Jan (CRPC) and I hope I'm done. Waiting on results from CFP exam (takes 6 weeks).
Old 12-18-2008, 06:27 PM
After the next project
x98boardwell's Avatar
Yoh!
Don,
My buddy just went for the week long course in November to Dallas for the study session for that test which he has also now taken. He is waiting the results. CFP, here you come. Best of luck.
Bryan
Old 12-19-2008, 07:28 AM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
Don, do you know which guides your previous machinist installed? Also, which stem seals did you use? Obviously these guides should be blacklisted.
I thought my exhaust guides were bad, with about 1mm clearance at 89k mi. Then at German Precision I saw some reeeeally worn guides, like you could put an extra valve or two in there!
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 12-19-2008, 08:01 AM
DonE's Avatar
I picked up my heads from Xtreme Cylinder Heads in Palm City FL this afternoon. Below are some pics of one of the heads, and a pic of the trashed valves (intake and exhaust).
The valves are custom stainless steel intake and inconel exhaust valves, both turned from blanks. The guides are manganese/bronze. The inconel valves cost $25 for the blanks and $25 to custom machine each. Stock exhaust valves are $48 each. The custom stainless intake valves cost $42 each (blanks plus machining) compared to $50 for stock.
The springs had to be replaced because of the new custom valves and their retainer positions. They are Elgin springs with titanium retainers. You'll see the top of the stems are a bit higher off the retainers than stock.
Here are the old intake and exhaust valves cleaned up, but clearly show severe wear. The intake valve has a ridge cut in it at the top of travel. The stems feel as if they where sanded with 50 grit sandpaper.
The engine should be back together around Jan 1.
Old 12-22-2008, 02:15 PM
DonE's Avatar
Here's the engine on the stand. You can see that I've packed the turbo shield with new insulation. After I took this pic, I joined the tranny and motor, so tomorrow it goes in the car.
Old 01-12-2009, 06:14 PM
Cynical Misanthrope
AFM744's Avatar
Originally Posted by done View Post
...so tomorrow it goes in the car.
woot!!!
Old 01-12-2009, 07:29 PM
ghnat's Avatar
Alright, can't wait to see the beast again...
Greg Hnat
98 Jeep Cherokee
Old 01-12-2009, 08:24 PM
purplehaze's Avatar
Nice work, Don!
Looking forward to seeing it back in your car.
When I think I've had a bad day, I just think of the ***** you've been through, and it puts it all in perspective.
Glenn
87' 930TT
Old 01-13-2009, 06:53 AM
