Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Looks good!
If I had access to a welder, I would have done the left side as well. Just didn't feel like doing all the work to trailer it over to a shop.
Old 11-23-2008, 02:08 PM
Smart quod bastardus
fredmeister's Avatar
Looks like my project when I went thru it 2 years ago....good job.
Make sure to weld all around the wevo to get good distribution of load to chassis sheet metal and make sure that you don't put heat into the plastic bushings if you use the sway bar assembly to hold alignment (act as a fixture) when welding in the mounts. You want to make sure they weld in linear alignment or you introduce binding in the sway bar when mounted.
Reundercoat everything and seal it well when finished so no rust forms.
Almost hated doing that because the Wevos look so cool.
See ya
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-23-2008, 02:14 PM
cl8ton's Avatar
Thanks guys!
Jim, I actually did all this work in my garage. I used a pneumatic cutoff grinder to get everything
off and cleaned up so all the welder needs to do is just show up and weld.
A friend of a friend who builds “World of Outlaw” sprint car tubular chassis is going to do the welding
for me, he has a mobile truck and will just back into my driveway and weld everything up for < $100.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 11-24-2008, 06:00 PM
A930Rocket's Avatar
Good deal!
I used a rust preventer, a self etching primer and then Wurth undercoating to try and match the factory as much as possible
Thanks guys!
Old 11-25-2008, 05:46 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
