Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
wcc wcc is offline
wcc's Avatar
Where to get a Clutch Pedal Return Spring
I'm in need of that Spring so if you guys know where I can get a new or used one please let me know. I've called a few places already and our host doesn't have it and so far, no luck.
Bill
Old 10-02-2008, 03:13 PM
cl8ton's Avatar
If your talking about this one, it is NLA every where I checked.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 10-02-2008, 03:15 PM
wcc wcc is offline
wcc's Avatar
That's it! So now what? Just live with a heavier clutch pedal? Has anyone figured out another option?
Bill
Old 10-02-2008, 03:18 PM
cl8ton's Avatar
If your clutch is heavy, I think that has more to do with your Omega spring at the transmission. Providing itís nothing internal with the transmission.
If your spring pictured below is in one piece, it should be good to go?
Rod...
Old 10-02-2008, 03:26 PM
wcc wcc is offline
wcc's Avatar
Maybe the heavier thing is just mental. Let me live with it a little while and it'll probably go un-noticed. It engages just fine like always. Maybe I'll just forget about it then.
Bill
Old 10-02-2008, 03:34 PM
full quack's Avatar
Send a message via Yahoo to full quack
Hey there WCC,
Mine snapped also, found another Porsche spring that works perfectly and is still available. The new one does not look exactly the same, it's just a 1 piece affair, but all it needs to do is work...right!
I will look up my receipt when I get home tonight and see if it has the part number listed. I think I also kept the broken one and put it in the bag the new one came in. Not 100% sure though, I will do my best and blast another message to this thread tonight.
Mark
Old 10-03-2008, 12:15 PM
full quack's Avatar
Hey WCC,
Sorry man, looked everywhere, can not come up with the PN#.
Have your friendly parts guy/shop look for a 1 piece spring that is the same overall size & length. The one I now have is bright blue in color and ran me about $30. I know my guy did a cross reference with the Porsche parts book, please don't quote me on this, but I think it was listed for a 1987-1989 930. And yes it is not the adjustable 3 piece affair, but it does fit & it does work great. It was however, a real ***** to put on, that's where the 3 piece adjustable one, might have been easier to install. Best of luck.
Mark
Old 10-03-2008, 06:14 PM
I've heard of people succesfully welding the spring back together if it's broken. and putting two of them on can help a real heavy clutch.
Old 10-03-2008, 06:37 PM
wcc wcc is offline
wcc's Avatar
full quack - Thanks for checking for me. A friend of mine suggested a tractor shop just trying to match size and length. The only problem with that is I only found one piece of it.
Bill
Old 10-04-2008, 04:19 AM
rsrmike's Avatar
Have you tried fishing around under the pedal cluster and up in the tunnel w/ a magnet? You wouldn't believe all the stuff you can find in there...
Professional Overcomplicator
Old 10-04-2008, 05:09 AM
930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
make sure you have the right ohmega spring , get the one with the 930 part # , the other one will fit and give you a wimpy pedal.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 10-05-2008, 04:23 AM
F350Lawman's Avatar
Mine broke and I have been running w/o for awhile...still feels fine though. I really don't miss it.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 10-05-2008, 06:28 PM
wcc wcc is offline
wcc's Avatar
I tried this a couple days ago with no such luck.
I've been driving without it for a while now and I'm getting to the point where I don't miss it either.
Bill
Old 10-06-2008, 07:27 AM
I needed the spring too and found this one. It is not adjustable and not as strong since it is a 911 spring. It helps some.
http://www.*****************.com/product_p/pp-911.423.305.06.htm
Old 10-09-2008, 08:50 PM
"I wuz the liquor..."
sand_man's Avatar
That part is also available from out host:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_Tclutc_pg5.htm#item15
-jeff
Old 10-10-2008, 03:23 AM
A fellow Pelacanite
NathanUK's Avatar
According to the description of the part (and reading this thread) this spring goes on the pedal assembly.
I'm pretty sure this spring is on the clutch lever at the tranny on my 915 carrera?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-11-2008, 02:49 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
