-   -   Exploring option (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/435012-exploring-option.html)
IDGAF27 10-11-2008 08:18 AM
Exploring option
Looking to obtan Front Mounted Oil Cooler for 86 930 . Any lead or idea what to get or where to look appreaciated.
BTW if I go w/front mount oil cooler , do I have to replace front panel of a trunk? or just a front bumper?
Also would love to get my hands on steel braided fuel lines. especialy in a rear.
http://forums.pelicanparts.com/uploa...1223738129.jpg
http://forums.pelicanparts.com/uploa...1223738271.jpg
carmad 10-11-2008 08:22 AM
Try Elephant Racing
ImagineAuto
Batinc
Do a search this has been covered before.
IDGAF27 10-11-2008 08:27 AM
Thanks.....
rsrmike 10-11-2008 10:39 AM
You could simply relocate your stock fender mounted cooler to the front bumper for much improved efficiency
It's best to change the valance although you can modify your stock one to allow airflow.
You don't have to cut the body but you need the cooler moved as far forward as possible to let as much air out from behind so you won't get too much turbulence affecting flow.
If you can get the cooler near parallel w/ the leading edge of the bumper, that would be ideal
Miguel Antonet did a really nice job doing just that on his 79 using his stock valance, it looks good too..
