-   -   Pulling diff out???? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/435044-pulling-diff-out.html)
jly535 10-11-2008 01:11 PM
I think my diff just went tits up, so I am pulling out this weekend. I got CV axle off and all bolts on diff side cover off. Do I need to remove big nut on center of CV axle flange on diff? Any other pointers or advice? I believe I have the Quaife ATB, will know shortly. Thanx, Jamie
A930Rocket 10-11-2008 01:19 PM
I've not taken mine apart, but there's more to it than taking the side cover off. That may give you some access, but I don't think it will really allow you to work on it.
Be careful.
jly535 10-11-2008 01:33 PM
Be careful.
I am sure I can pull the diff out without removing trans, then work on diff on bench or send out for rebuild. Thanx for input, Jamie
rsrmike 10-11-2008 03:11 PM
take both axles loose, remove both drive flanges, pop diff cover off and diff will fall in your face
Yes, be careful, it's heavy and awkward
jly535 10-11-2008 04:58 PM
Thats what I needed, Thanx, Jamie
