"O Gruppe 13"
IDGAF27's Avatar
Send a message via Skype™ to IDGAF27
WTB parts
Picture provided of part I am looking for. Second pic is upclose:
Here is one more pipe I need to replace:
G-Man
89 964 C4
86 930
Old 10-11-2008, 08:26 AM
rsrmike's Avatar
If they are not leaking, you should be ok
Those dents don't affect flow as much as it may seem, although I can relate to being disturbed by them...
Good luck
Professional Overcomplicator
Old 10-11-2008, 10:21 AM
Blitzkrieg
jly535's Avatar
Just remove the one with six pipes to each exhaust port, it is just air pump fittings and does nothing for performance, I was actually told it can damage exhuast valves. Just plug all six holes with I believe a M10x 1.5 set screw, they are hard to find at hardware stores because it is a fine thread, Pelican Parts sells them. As far as the turbo oil tank, just leave alone or buy a new tank.
Old 10-11-2008, 10:56 AM
Send a message via AIM to Chuck Jones
If you decide to plug the air pump ports, make sure you use the Pelican plugs and USE SOME LOCKTITE. I had three of the plugs fall out, (not the Pelican ones) even after I torqued them in then went back and retorqued them.....and had to take my SSI heat exchanger off again just to get at the place where one of the plugs was inserted. They can be a PIA if they start falling out like mine did....and makes your car sound like a 67 VW with a cracked exhaust. I actually ended up using a grub plug.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 10-11-2008, 11:27 AM
A930Rocket's Avatar
Diito on what the others siad.
BTW, it that a forklift lifting the engine (car) up?
Old 10-11-2008, 01:26 PM
"O Gruppe 13"
IDGAF27's Avatar
Yep, that is forklift, kind a on big side lifting the whole car. My son calls it "Guido" as per "Cars" movie.
G-Man
89 964 C4
86 930
Old 10-11-2008, 02:15 PM
A930Rocket's Avatar
Well thats got to make it easier to work on. I'm so tired of working on my back.
Old 10-11-2008, 10:01 PM
930gt-40r's Avatar
IDGA- is that a 964 in the first picture? I love the rims on your car too.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 10-12-2008, 09:07 AM
"O Gruppe 13"
IDGAF27's Avatar
On first pic is 91 964. Currently pending sale.
Rims!?!? OMG, I love them. There was one roler body for sale , couple months back. I got into the deal only for rims and tires. To bad ( or maybe for good) that car didin't go my way......two months later I got this one.
G-Man
89 964 C4
86 930
Old 10-12-2008, 11:34 AM
MEMBER # 930
waynesco1's Avatar
There is a air pump pipe assembley on Ebay now .
MEMBER # 930
Old 10-12-2008, 07:27 PM
Good eye Wayne....I was just going to refer him to eBay item number 290266193401 ...complete assembly currently at $36.....hard to find item...you might want to get in on it.
Good luck......Chuck
Old 10-14-2008, 09:51 AM
"O Gruppe 13"
IDGAF27's Avatar
Thanks guys. I wish I knew item number before Lucky me , seller has few more stuf for sale, contacted him . Hopping he'll respond and I get that thing
Thanks guys
G-Man
89 964 C4
86 930
Old 10-14-2008, 01:58 PM
"O Gruppe 13"
IDGAF27's Avatar
Thanks guys. Got that part. I mean paid for it and waiting for arraival.
Still exprloring option to go w/out air pump and injection lines, but bigest concern is emission test . In NJ , inspection station , fails you right away if there is original equipment missing . And on top of it I am not sure I would pass emmission test w/out it and it is too mutch of a hassle to keep taking out and putting back.
So I am in crossroad. Only thing for sure, if I wiling to have everything is supose to be there , I will have unharmed and undammaged pieces.
G-Man
89 964 C4
86 930
Old 10-15-2008, 06:04 PM
