Me like track days
Craig 930 RS's Avatar
Edge margin is too short, and the wheels - as mentioned above - are designed for a short life cycle.
I do like them on your car and I do hope you find a replacement!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 10-20-2008, 09:39 AM
935TURBO's Avatar
The look is really nice...but I agree that if they are so "fragile"...i'll have to do something.......
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 10-20-2008, 10:00 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Not sure if would have helped, but there should have been a washer under the bolt as well to spread the load.
Old 10-20-2008, 10:18 AM
What torque setting was being used on the bolts?
Bryan O.
77 930
08 Boxster
14 535i M Sport
Old 10-20-2008, 01:06 PM
935TURBO's Avatar
It has been done by MCG (some of you saw their productions...) ....they are professionals......the standard BBS recomandation 1.5 m/daN.....sorry for the conversion.....
MCG...... http://www.mcg-propulsion.com/accueil.htm
Old 10-20-2008, 01:12 PM
if the ring bolts are not checked from time to time they loosen up.most often they break off if loose.and or fracture ring side of rim.from my experiance with bbs 3 piece wheels.
Old 10-21-2008, 10:19 PM
A fellow Pelacanite
NathanUK's Avatar
I thought that too!
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 10-22-2008, 01:53 PM
BBS RSR Wheels for Sale
Old 10-29-2008, 11:27 PM
935TURBO's Avatar
The rims I've got have no gasket in the middle of the 2 halves....some people here told me that it could be the reason of the damage....???.....can somebody here confirm this......?......thanks to all for your help......
Old 10-30-2008, 11:24 AM
gumba's Avatar
In theory your suppose to change the gasket when the wheel halves are taken apart. Some folks used silicone sealer instead. I think this was to get around the $40.00 per gasket charge. I've used both methods and never had a problem. I run the 3 pc bbs rims w/fuchs centers on the track and street.
I was told the torque was 12 f/lbs. (or 144 in./lbs) by Bob Woodman. I found about 3-4 bolts would strip out using this torque setting.
Did you try talking to tech support at BBS about the cracked rims?
Old 10-30-2008, 12:18 PM
A930Rocket's Avatar
Looking at the European website for BBS, I see that you can get just the rubber ring instead of the aluminum ring with rubber ring attached. It's got to be much cheaper to replace the rubber ring, rather than both as a unit.
The last time I rebuilt mine, I noticed that a few bolts seem to be loose later on. I re-did all of them with a little red Loctite for insurance. As I was loosing a small amount of air in several wheels, I also ran a bead of HTV silicone on the inside between the two halves after bolting them up. No leaks after months.
A in/lb torque wrench is a must at 144. Not a ft/lb torque wrench set at 12.
Old 10-30-2008, 04:52 PM
