9dreizig's Avatar
Location: Reno NV, Bay Area during most weeks,, Kids still in NH
Send a message via AIM to 9dreizig
vacuum lines help
Geez seems like I start a new thread once a day..
So I've ripped out the air pump , solonoids etc and now need to figure out the vacuum line scheme.. My 86 disti has two vacuum line inputs..
Does anyone have any suggestions ? I assume the rest of the lines get blocked off ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-27-2008, 03:49 PM
resident samsquamch
sand_man's Avatar
does this help?
-jeff
Old 10-27-2008, 04:22 PM
9dreizig's Avatar
Thanks Sandman,, but my distributor has TWO outlets and I"m trying to figure out what to do with the extra vacuum lines and where to route the existing ones..
"Todd"
Old 10-27-2008, 04:29 PM
After the next project
x98boardwell's Avatar
Thoughts and Bump
I know that they are for the vacuum advance and retard and they are most affected on cold start up I think. Not sure if this helps, but at least your back on top.
Sorry I cannot offer more advice.
Bryan
Old 10-27-2008, 05:24 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
if you follow sandmans diagram, there is vacuum line that goes from the vacuum advance canister on the dizzy to #7, the thermo valve and then the throttle body. Connect it directly from the dizzy go the throttle body, above the butterfly valve.
For the other one off the dizzy, I ran it directly to a thermo coupling right in front of the crankcase breather. Basically what it was doing before, but with out any stops.
Everything else gets plugged.
I'm on my iPhone or post a picture.
Old 10-27-2008, 06:37 PM
9dreizig's Avatar
Thanks 930,, say where is Mt Pleasant SC ? My parents live in Lake Lure N.C
"Todd"
Old 10-27-2008, 08:06 PM
A930Rocket's Avatar
Mount Pleasant is just over the Cooper River, north of Charleston.
Old 10-27-2008, 08:31 PM
Certified User
billjam's Avatar
Sandman should have looked over the page! Sorry about the crappy quality of the copy, but at least you can see where the dizzy vacuum lines should run.
Does anyone know what effect item 9 has? It has been blanked off on my car.
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 10-28-2008, 04:45 AM
9dreizig's Avatar
Thanks Billjam, my 86 doesn't have that either, never did from what I can tell but it's not a Californial car!!!
"Todd"
Old 10-28-2008, 05:06 AM
A fellow Pelacanite
NathanUK's Avatar
If you are still not sure about the dizzy hoses I can check for you, just ask.
On my car one hose is red, the other blue. They are slightly different diameters which helps to identify where they go too.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-08-2008, 02:17 AM
9dreizig's Avatar
Thanks Nathan I'm OK I think,, I am still waiting for the injector I ordered from DC automotive to arrive ( $25 used) and am anxious to fire it up again..
"Todd"
Old 11-08-2008, 07:36 AM
A930Rocket's Avatar
My 87 had that. I believe it's part of the emissions. When I re-ran my vacuum lines, I removed that and ran a continuous line from the dizzy to where that part leads to.
Old 11-08-2008, 07:02 PM
The vacuum solenoid in the vacuum retard line disconnects vacuum retard for a short time after a cold start so ignition timing is advanced for around 40 seconds.
That helps raise the idle speed along with the cold start throttle bypass valve during a cold start.
You can hear the engine drop in revs during warmup when the solenoid opens allowing vacuum retard at idle, pulling the idle ignition timing back a bit.
The throttlebody air bypass valve is also slowly closing but not as abrupt.
It may also do something at full throttle via the throttle position switch during boost retard.
Old 11-08-2008, 08:31 PM
Registered Driver
Helmsy's Avatar
I have been having problems with CP's and scratching my head checking lines and blaming the WUR however one of the symptoms is that during warmup and cold startup it idles low (about 400-500rpms) but idles perfectly when warm/hot.
I am now thinking that I should check the vacuum solenoid and dizzy advance/retard module for malfunction and air leaks.
I also have the thing is your #9 pic but there is a 3rd variation. See Euro vacuum diagram:
Is there something else which could cause the revs to be really low until the engine is hot then idle fine (about 900rpm).
The other symptom is mild bucking at slight throttle and the occasional small miss when accelerating after maintaining throttle position but this will entail a whole new thread so I won't hijack this one.
Ben
'85 930 - Black on Black
'95 993 Turbo - Silver
Old 11-09-2008, 10:45 PM
"Is there something else which could cause the revs to be really low until the engine is hot then idle fine (about 900rpm)"
Yes, if the throttle bypass valve #4 in your diagram is not opening when the motor is cold then your idle will be real slow like you say.
Take the hose off the inlet side and look in to see if the slide valve is open or closed when cold. There is a slot in the valve too.
The valve is opened or closed by a bi-metallic spring. There is a heating element to gradually heat up the spring and open the valve slowly when the fuel pumps are running.
It may just need a little WD40 sprayed in there to free it up or it may be shot.
There is a valve made that is manually controlled that you could put in place there for testing. You can also hook up a long generic choke cable to it so you can operate it manually from the inside of the car.
I've done that on L-jetronic BMW's because the cold start throttle body air bypass really makes the old L-jetronic big 6 cylinder BMW's rev annoyingly high when cold and for way too long.
It is the black plastic heater valve for a water cooled 944 or BMW 320i.
It has the same size hose connections as the aux air valve or throttle bypass valve on CIS. Installed correctly it will work perfectly for this if you want to do that.
Even cheaper and made of metal, is to put a ball valve there with the correct size hose fittings screwed into it. You can make one of those up for about $5-$8 at harbor freight tools.
Some crazy ideas, but they do work...
Old 11-10-2008, 10:13 AM
Registered Driver
Helmsy's Avatar
Thanks Fairman.
I will check this weekend. My dizzy also has 2 lines even though I have a euro system so I think i need to follow and check my vacuum lines to see where they go and also make sure none are leaking.
Also what do #12 and #14 do in the Euro pic above? As I have no air pump my #13 is just connected to the valve houseing (bov). Can I just eliminate #13 and plug the housing?
Ben
Old 11-10-2008, 04:12 PM
I found my red fabric covered vacuum advance line dry rotted and blown off of the thermal switch behind and under the CIS unit when I removed it recently, so I had no vacuum advance and didn't know it for a while.
#12 is vacuum operated diverter valve.
#13 is a 12 volt vacuum solenoid valve.
#14 is a large check valve.
All of these parts are for the air pump system only and can be removed if you're not using that.
You can use the vacuum solenoid for other things.
Old 11-10-2008, 04:32 PM
