nreed's Avatar
Width of 930 flywheel seal?
Can someone please tell me what the width of the 930 flywheel seal is?
Part number 99911342641
In Wayne's book it says 90x110mm but no width.
Thanks!
Norm '86 930
DTA P8Pro ECU - Synapse BOV - 60# Siemens inj - K27HF - Dual GHL - Kokeln IC - Elgin SC330 cams -
HRE 560R 8.5x18 ET25 11x18 ET0
https://flic.kr/p/nVgoAC
Old 10-27-2008, 05:01 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I'm going to guess it's 90mm ID and 110mm OD, making it 10mm wide.
Old 10-27-2008, 05:13 PM
nreed's Avatar
If you mean 110-90 that's 20mm but I don't mean that direction
Norm '86 930
Old 10-27-2008, 05:15 PM
A930Rocket's Avatar
I was thinking 20mm /2 = 10mm.
You want the depth?
Old 10-27-2008, 06:01 PM
Certified User
billjam's Avatar
I just measured one I removed recently and it is 12mm wide.
ID = 90mm, OD = 110mm (but you already knew that!).
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 10-28-2008, 03:56 AM
nreed's Avatar
Thanks Billjam...that's what I was looking for. I want to try and get one from a company like Chicago-Rawhide. I'm told they make double spring seals and I wanted to be able to spec the width...and order one before I take things apart.
Thanks again!
Norm '86 930
Old 10-28-2008, 06:29 AM
