Thanks Julian, will call later today!
This pic is my nightmare :eek: Not my car, but I start sweating every time I see it... http://forums.pelicanparts.com/uploa...1225813666.jpg |
:eek:Oh the humanity! I waste no time in getting that folker back on the ground as quick as I can:eek:
Another benefit to dropping the engine/tranny with the car resting on its tires, is that you don't have very far to go to get it on your dolley or whatever...
I trust the jackstands that I got though- they are very heavy duty. |
That picture less pleasant than a decapitation...
I always stick the jack stands under the control arms of the car. |
I'll get you ca dollar, the owner placed that jackstand on the end of the spring plate cover. An easy place for it to slip off. I've installed a muffler clamp on the end of mine to keep it from sliding off, but if I'm getting under the car, I place it under the torsion tube on the inside if the frame rail. Sometimes I add more under the control arms.
| All times are GMT -8. The time now is 06:42 AM. |
