boostfix's Avatar
Accuracy of OEM boost gauge?
Does anyone have any experience of how accurate their OEM boost gauge reads?
My OEM gauge has only ever shown a boost level of 0.5 bar, in the time that I have owned the car, so I'm trying to understand if I have a problem to fix. I have never driven or had a ride in another 930 so my seat of the pants boot gauge has had no calibration experience.
Dan
88 930 blk/gry
Old 11-06-2008, 06:56 AM
Registered Abuser
MT930's Avatar
I have found mine to be very inaccurate.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 11-06-2008, 08:28 AM
Wayah Road Warrior
Shadetree930's Avatar
Is the gauge you are talking about in the tach or replacing the clock?
In tach - worthless for anything except amusement
In clock position - dead nuts accurate
Of course, this is my opinion. YMMV
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 11-06-2008, 09:31 AM
Zero to awful.
It's like the oil level gauge, something to fill space and cause confusion.
Very slow to react and not reliable. I don't know if it is the sending unit, the gauge itself or all of the above. It's a good reference as the inaccuracy is constant so it's useful to detect changes.
If you have time to read that small gauge while on boost, then it is probably a good indication that you indeed have boost problems!
Jim
1980 930
1995 995
Old 11-06-2008, 10:29 AM
boostfix's Avatar
I might indeed have a problem then! Time to make a plan. Thanks for the comments guys. (I am asking about the OEM gauge built into the tach)
Dan
88 930 blk/gry
Old 11-07-2008, 06:28 AM
resident samsquamch
sand_man's Avatar
Zero to awful.
Agreed! The boost gauge within the tach seems to move with the slightest bit of engine breath!
As for the oil level gauge, mine is dead on accurate, and jives with what the stick says. Of course this assumes typical Porsche oil check procedures: car warmed up, level ground, engine idling, wait about 30 secs...blah, blah, yada, yada...
When it's cold, yeah, the level gauge no worky!
-jeff
Old 11-07-2008, 06:36 AM
The manual states not to pay attention to the oil level gauge until the oil is warm, car is level, bla bla bla. I bought my car in Texas and dove it home to Atlanta in one shot, the next morning I took the car out to run an errand and freaked out when the oil level gauge was flat. I went home and checked the manual and I have used it as a rough guide ever since.
My factory boost gauge seemed more like an on off switch and with a 1 bar spring the information I really wanted to know was off the scale of the gauge. I replaced mine with and LCD system that I am happy with.
1987 GP White 930
1977 Ford Bronco
Old 11-07-2008, 07:17 AM
Does the boost level change depending on outside temp?
Mine gets/shows higher boost level during cooler weather, but the car feel the same.
Old 11-07-2008, 07:57 AM
Smart quod bastardus
fredmeister's Avatar
Totally inaccurate. Get yourself the VDO gage that mounts in the closck location. Much more accurate though probably still liable to +/-0.1 bar inaccuracy.
At least it will tell you vacuum unlike the tach gage.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-07-2008, 08:40 AM
Boost Freak
Maxx1's Avatar
Red face
That's good to know. Mine pegs 1 bar under full boost and I've been concerned that if it's on the high side, I may be in trouble. I have a tial 1 bar spring in there..... maybe I should install a .8 or so as a safety measure?
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 11-07-2008, 11:35 AM
beancounter
jwasbury's Avatar
I recently installed the boost/vac gauge from NHS in the clock location (gets boost signal off of brake booster hose). My observation in comparing the two is that my tach gauge is reasonably accurate at telling me full boost level...But it reads very different from the mechanical gauge when the boost is building. For example, the tach gauge will show .2 bar while the mech gauge shows that manifold pressure is at atmosphere (0 bar) or even a slight vacuum. My understanding is that this difference is due to the fact that the mech gauge reads after the throttle plate, and the factory tach gauge sender is before the throttle plate. I do think that factory boost gauge sender in my car is not original (looks too shiny so must have been replaced at some point).
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 11-07-2008, 02:56 PM
