Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
iamchappy's Avatar
Pat i had my sc distributor converted to 12 plug and have a boost retard MSD but dont use the retard
function at all. I had my timing set at 26 at 4500 and all has been fine. I still think the simplest thing for you to do is sell off the BAE stuff and SS box, install a 930 intake and some boost tolerant pistons and cylinders run .8 bar and be happy, happy , happy.....
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 11-12-2008, 04:48 AM
one of the great unwashed
patkeefe's Avatar
Chappy,
At the moment, I am looking at cost avoidance. Otherwise, I agree with what you suggest. I would probably be pretty happy with a 3.0 with PMO's and Mod-S cams, and great throttle response acroos the rev range, but I'm trying to be low budget. I'm going to go with the JE pistons, maybe a bit less than the 8.5:1, and run what I have.
Did you get your distributor recurved when you converted to a dozen spark plugs? I'm pretty sure I was running around 27 degrees total, which all came in around 3000 RPM, so it was pretty much stock SC timing. The SC likes the advance up to 3k.
Pat
Patrick E. Keefe
78 SC
01 Boxster
Old 11-12-2008, 06:32 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
problem with adding a distributor that rotates the opposite way is. While the gear can be changed to the engine you have, it will rotate in the wrong direction causing the timing to automatically retard the full amount the dizzy is designed to advance. The only way it would work is if the crank drive gear was changed out also so it would turn in the right direction.
87 911 Carrera platform
Twin Garrett's, Big Valve, Xtreme Cylinder Heads, JB Racing cylinders and machine work, custom JE pistons, GT2 EVO cams, GT3 oil pump, modified 3.2L intake, 80mm TB, custom Intercooler, equal length headers, DFI, KEP Stage 2 custom twin disc, G50 custom gear set, LSD, Tilton trans pump, Fluidyne cooler
Old 11-12-2008, 06:35 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Yep. I forgot about that.
Old 11-12-2008, 11:29 AM
patkeefe's Avatar
Yup, crank gear needs to be changed to a 930 gear. Don't know if it's worth the trouble with all of the electronic boost retard devices available. But, it's easy enought to do now while it's apart.
Patrick E. Keefe
78 SC
01 Boxster
Old 11-12-2008, 01:26 PM
Agreed. But am I missing something? I thought the SC and the 930 both rotated the same way - e.g. CCW - and it was the 3.2 that rotated CW?
'77 S with '78 930 power and a few other things.
Old 11-16-2008, 01:38 PM
patkeefe's Avatar
Spuggy:
I may be the one who is missing something. I'm pretty sure my distributor rotates CCW looking down at it. Which way does the 930 rotate?
Anyway, I think I can just put the advance retard mechanism on my distributor and replace the strictly vacuum unit. I'll go out in the garage in a while and take a look at it.
Patrick E. Keefe
78 SC
01 Boxster
Old 11-16-2008, 01:59 PM
Originally Posted by patkeefe View Post
Spuggy:
I think 81 turbo and up rotate the same as the sc it could even be as far back as 78 but I know that 76-77 are the oposite.
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 11-16-2008, 02:09 PM
Interesting! Another wrinkle, never realized the 3.0 930's were different...
I have an '86 distributor in my '78 right now. I thought all the 3.3's were the same.
Old 11-16-2008, 03:27 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
911 (1965-1977) turn CW
911 SC's (1978-1983) turn CCW
911 turbo's (1978-1989) turn CCW
911 (1984-1989) turn CW
Old 11-20-2008, 07:10 AM
Manassas, VA
lucittm's Avatar
Add to your list:
911 turbo's (1991-1994) turn CW.
Thanks,
Mark
1991 964 Polar Silver Metallic Turbo Coupe
Old 11-20-2008, 08:25 AM
patkeefe's Avatar
Thanks! At least I don't have to change the gear.
Patrick E. Keefe
78 SC
01 Boxster
Old 11-20-2008, 12:20 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
