Arrgh Matey!
chesireIsugaree's Avatar
Porsche Crest New 930 Owner, need to get started...thanks!
Hi Guys,
I made a post yesterday about the missing rear oil cooler and electrical plugs hanging around.
As for the suspension, see the passenger side wheel in the pics...it's measuring 2.25" in from the fender lip while the driver wheel is only .5" Any ideas what my damage could be here or could it just need a good ripping after years of sit. What's the best way to get this car started.... Should i check all compressions before trying???
THANKS!,
Mason
PASSENGER SIDE SUNK INTO THE WELL
HERE IS THE DRIVER SIDE LOOKS NORMAL
And here are the connectors dangling back there.... Any clue what they are?
And lastly,
This is the only rear fitting I see...So this goes to a cooler and then into the oil filler??? Or Am I missing a set of lines? Thanks guys!!!
Mason
'90 Gt Black/Black 90k
Old 11-10-2008, 04:32 PM
78P930's Avatar
You may have a broken rear torsion bar on the drivers side. The single hose looks like one of the to the AC compressor that you have the bracket for but no compressor. It would help to know where the other end of the wires go..the two cut wires I look like mine from an after market security system.
congrats and good luck
10 Ford Raptor
86 930
Old 11-10-2008, 04:52 PM
Arrgh Matey!
DANG... broken stuff THANKS! ROCKET SLED ROCKET SLED!!!!!!!!! That's an AC LINE!? Where can I buy a torsion bar if it's busted or is it fixable....?
Mason
Old 11-10-2008, 05:03 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
It looks like some paint and body work have been done. Could it be that one or both flares were not installed correctly? What wheels do you have? Are the offsets the same? I'd get an alignment to see if there is any problem with the suspension. They might be able to tell you about the frame.
The one hose by the oil filter is an AC hose as mentioned. The wire near there is a right rear tailight wire I think.
Does the wire with the plastic terminal plug into the CDI ( the finned box on the bottom )?
Old 11-10-2008, 05:06 PM
A930Rocket's Avatar
You can replace it, but NOT repair it. I would think about doing it in pairs as well look in the parts for sale here or DC Automotive (google it) in NC.
Old 11-10-2008, 05:10 PM
Arrgh Matey!
This is a 930 Vin starts with 930...
I'm not sure... will look. As for flares, these are factory flares- Vin starts with 930...
What is the nipple on the oil filler for? Is there supposed to be an oil cooler in the tail?
Mason
Old 11-10-2008, 05:12 PM
Arrgh Matey!
What breaks it... a tow truck??
Mason
sudo apt-get purge 930
equality72521's Avatar
The three prong plug goes to what used to be an external voltage regulator. Someone swapped it with a newer internal voltage regulator model.
--clutch-monkey
Old 11-10-2008, 05:13 PM
Arrgh Matey!
Cool, no worries then. Dc's site is excellent. I can't believe I hadn't seen it yet. I guess all that's left is the oil cooler ? And then try to crank it up...
Mason
Old 11-10-2008, 05:19 PM
A930Rocket's Avatar
No. A scratch can lead to rust and that leads to a broken t-bar.
Old 11-10-2008, 05:20 PM
A930Rocket's Avatar
Has the body been worked on? One of the rear flares?
The nipple or fitting on the oil filler goes to the air cleaner IIRC.
No oil cooler in the tail. There is an AC condensor that goes there on the right side.
What is the nipple on the oil filler for? Is there supposed to be an oil cooler on the tail?
Old 11-10-2008, 05:22 PM
Post more pics of both left and right side flares with the door lines in the pics. It appears that the flare on the passenger side is much wider than the driver side from the pics above.
--clutch-monkey
Someone has definitely shot the rear of the car based on the over spray on the cdi.
--clutch-monkey
Old 11-10-2008, 05:24 PM
Also, the wire near the oil filter connects to the AC that is no longer there. It operates the AC clutch. You should have another hose connected to the condenser in the tail.
--clutch-monkey
Old 11-10-2008, 05:27 PM
A930Rocket's Avatar
Quick tip: buy the 911 Turbo manuals.
Old 11-10-2008, 05:32 PM
Arrgh Matey!
Mark,
on my 79 is this oil cooler back there? under the bumper? I'm missing #37 below... Air filter you say
Mason
Arrgh Matey!
You right your right.... Maybe there is damage to the car, won't have a chance to work on it for a few weeks. Isn't that killer!?
Mason
Old 11-10-2008, 05:34 PM
Arrgh Matey!
Yeah whats up with homey in the UK? He's offline now?
Mason
Old 11-10-2008, 05:35 PM
37 is the breather hose from the oil tank (10) to the intake. The oil cooler is #8
--clutch-monkey
Old 11-10-2008, 05:38 PM
pm sent
--clutch-monkey
Old 11-10-2008, 05:40 PM
