-   -   Rear wheel bearings replaced???? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/441185-rear-wheel-bearings-replaced.html)
jly535 11-13-2008 06:50 PM
So I got everything back together smoothly, and my question is, is it normal for new bearings to have some resistance to spinning nice and freely. I haven't torqued nut to 250 lbs yet, but just spinning with hand it is not as free wheeling as I thought it would be, even with tire mounted I bet it wouldn't spin more than a revolution or two by hand. WTF?? I plan on torquing nut down, then release it and final torque it. Can anyone put my mind at ease?? Jamie
bcoats 11-13-2008 07:53 PM
you just need to crank some Cyanide and all will be good bro. . .
full quack 11-14-2008 10:39 AM
Are we talking axles all bolted up, rotors & calipers bolted up, e-brake assy. installed, and now it is not spinning freely?
Or are we talking hubs assembled in trailing arms with new bearings and nothing else attached, and not spinning freely?
Mark
jly535 11-14-2008 10:48 AM
Mark
Mark, just the hub with new bearings and seals, no park brake, axle shafts or rotor. I am confident that everything went in straight and races are bottomed out. The only thing I didn't replace was spacer between bearings, it looked fine and didn't see any reason to spend $100 on a new one. Just got off the phone with Monty at Redmond Euro and he said to torque nut down to 240 and back off abit to preload bearings and see if that helps. Hub spins with no binding or noise, but I just thought it would spin nice and freely. Any other suggestions, befor I start over. Jamie
full quack 11-14-2008 11:01 AM
I'd go with what Monty says...he's never steered me wrong!
Mark
David 11-14-2008 11:26 AM
As long as it's not binding or grinding, it's probably fine. The only way they'd really spin free is if there was no grease and loose tolerances.
jly535 11-14-2008 11:31 AM
Thanx Shifter, that puts my mind at ease abit. I think I will just torque nut to preload bearings and call it good, put a few miles on and recheck.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
