rocker panels remove, what will I find there?
I am considering to remove the rocker panels from my `87 930...
I so much like this one:
what will I find when I remove my rocker panels?
What work is necessary to get close to above look?
thanks
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-23-2008, 10:08 AM
Along the same lines, I am wondering if you can just peel off the black sticker covering the torsion bar hole on the rear quarter fender. Does that ruin the paint job underneath?
Old 11-23-2008, 11:08 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
There will be holes in the rocker panel below, but not many. Maybe 5-6. You'll have to fill in the holes in the fender wells from the boxed rocker end caps as well.
I think depending on the color of your car, there will be some paint fade.
Old 11-23-2008, 03:05 PM
David's Avatar
Anyone know if the they add to high speed stability?
2014 Cayman S
2011 Cayenne Turbo
Old 11-23-2008, 03:57 PM
Certified User
billjam's Avatar
Yes.
They help keep the center of gravity low
Bill
1988 Carrera - 3.6 engine (with ITBs, COPs, MS3X) and a whole set of turbo body panels waiting in the attic.
Day job ... www.sspowdercoat.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911
Old 11-23-2008, 08:13 PM
Originally Posted by billjam View Post
Yes.
Especially after they collect pebbles and gravel, really weighs down the sides of your car nicely....
Old 11-24-2008, 06:03 AM
...fine so far
maybe pictures available showing the area after
freshly removed rocker?
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 11-24-2008, 06:56 AM
I pick this old threat up, because today I removed one rocker panel.
Good and bad...
The good news is, I am sure I was the first who ever took them off,
only very few rust points around the holes for rocker panel screws.
bad news: There is a cover plate which is partly under the black sticker.
This plate is a single part.
To get the desired RSR look, it is necessary to use plastic prime?
and model the hole for the torsion tubes.
I was thinking to be able to put the rocker panels on some day
to get the original 930 look back.
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 08-08-2010, 08:38 AM
