-   -   Who can I get to reman injectors? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/443426-who-can-i-get-reman-injectors.html)
h20cooled7 11-27-2008 03:48 AM
Sending WUR out to Brian Leask and want to get my injectors redone. I want to start out fresh. Any1 recommend somebody to rebuild injectors so I can get Miss Piggy back in shape without getting slapped w/new injector prices.
9dreizig 11-27-2008 05:03 AM
Do a search there's a couple on cleaning injectors.. You can do a quick check on them by taking carb cleaner with the narrow straw on the can and checking the spray pattern..
Otherwise I'd say buy some used ones they are $25 from DC Automotive and other places.. Not sure anyone can actually "rebuild" them just clean them up
h20cooled7 11-27-2008 12:45 PM
I could of swore i saw a blog about it on here, i have the bosch fuel/diesel injector tool at work, the 1 for checking the breaking pressure(cracking maybe). can i use this with some 44k to blow thru the injectors to clean them up.
h20cooled7 11-27-2008 01:06 PM
might try the backflush method that i came across here.
ghnat 11-27-2008 05:31 PM
How about
http://www.witchhunter.com
h20cooled7 11-28-2008 09:44 AM
Will Witchhunter do a good job or will the backflush method be about the same?
ghnat 11-28-2008 10:00 AM
Lots of threads about them on the 911 forum...
http://forums.pelicanparts.com/search.php?searchid=2814185
I have not used them yet, but I plan to...
h20cooled7 11-28-2008 12:59 PM
thanks for the info ghnat
jwasbury 12-02-2008 09:34 AM
FYI gents, I checked with witchhunter recently and he no longer offers cleaning services on CIS injectors. He says he will test them for you, but nothing else.
Craig 930 RS 12-02-2008 10:11 AM
witchhunter is in my neighborhood -
FWIW, when he tests them he *uses the cleaning fluid to test* --- thus effectively cleaning them as much as possible.
I'd defintiely recommend them, he is very thorough and accurate - did a great job/analysis on mine!
ghnat 12-02-2008 01:56 PM
You could also try
http://www.rceng.com/index.aspx
or
http://www.allcarbs.com/parts/parts_fuelinj.html
or
EBS
Maybe one of these folks will work on CIS...
ghnat 12-02-2008 02:12 PM
One more to add...
http://www.cruzinperformance.com/
silver911rdb 12-03-2008 07:32 PM
I used Marren Fuel injection in Connecticut when I rebuilt my 993 3.6 liter engine. They did a great job rebuilding my injectors. They also provided a full printout report including flow rates before and after the rebuild.
