Max Sluiter
Flieger's Avatar
What is the difference in cooling between spraying the intercooler with water or some other coolant and spraying water/alcohol into the intake air charge?
I realize spraying the H2O/CH2OH into the airstream will cool the engine more quickly but do you really need that quick reaction? If you spray the intercooler sooner and have proper airflow, there should be roughly the same amount of heat energy removed.
Does H2O in the combustion chamber have any detrimental effects on power or is it miniscule in the concentrations being used here?
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 12-02-2008, 08:49 PM
Smart quod bastardus
fredmeister's Avatar
I think it would be alot easier to cool the outside of the intercooler than running plumbing to spray inside the intake manifold. The added benefit of having the vapor resultant sucked over the engine by the cooling fan to add extra engine cooling.
This should make the intercooler more efficient and thus reduce intake charge air temps. Spraying water or windshield washer fluid tapped off the existing fluid tank in the front fender shold work nicely.
I wonder if anyone has taken temp readings of the intercooler charge air between the intake and outlet to see what temp rise during on track boost type cycles. Then spray the coolant mist on the intercooler surface and see any drop in delta temps.
Anyone done this yet?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-05-2008, 08:18 AM
Me like track days
Craig 930 RS's Avatar
I'd say this is a waste of effort for a 930.
I've messed with it and it is....a mess. Water on the IC = a drippy mess at the bottom of the intercooler, with no appreciable gains.
Your smartest move would be:
A) Sealing off - shrouding - the IC to the tail
B) Attaching pull fans to the underside of the IC - this makes a BIG difference.
Reduced my outlet temperatures by about 30 degrees, down to 130 max from a dangerous 160 -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 12-05-2008, 08:36 AM
930gt-40r's Avatar
I want to try what Craig speaks of by shrouding the I/C better to the wing and then adding some nasty fans underneath it. I also want to put a meth-injection system in- I want it all in order to keep intake temps down.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 12-05-2008, 11:27 AM
Me like track days
Do it! But skip the injection - the temps will be nice and low w/o it.
I use an Andial an IC in/out temp gauge which verified my 'experiments' ;-)
Old 12-05-2008, 12:25 PM
930gt-40r's Avatar
I am going to do the fans and shrouding and when money allows maybe the injection, but if I am going to do it I will have to do it my way. But the next sizeable chunk of change I get will be for better brake pads and maybe rotors (uhhhumm- Craig...)
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-05-2008, 09:53 PM
Metal Guru
911nut's Avatar
Fred, the water/meth injection directly into the tb is more efficient because it would take far less coolant for the same reduction in temp than if you were to spray coolant directly onto the i/c. To cool externally you'd maybe have to carry 15 gallons of coolant on-board vs. 1/2 gallon.
I also don't think the level of mechanical complexity would be much different between the two systems.
Paul B.
'91 964 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, - 210 lb
Old 12-07-2008, 05:02 AM
Schwarzeritter's Avatar
Location: PaloAlto Calif, IndianWells PalmDesert, Japan
hmmm.
I think most of what you wanted to know was answerd but i'll add to this.
typically I dont like such kits myself, but they can have very rewarding benifits.
A. I never liked the idea of spraying directly onto the intercool a combustable fuel regardless.
It's just common sensible thought.
B. If you are going to spray a liquid substance onto the intercooler I recommend a distilled water, however this will be most efficiant when moving. In my opinion, for most Porsche applications its somewhat a cumbersome outfit.
C. If you are going to directly inject a fuel of some type, Aquamist is pretty popular.
They are typically standalone, they can be triggerd psi, rpm, and other various ways.
I also want to point out that you are going to take into consideration that meth typically
will mix into your oil and cause it to thin out and not provide you with the same resistance
it once did.
Good luck.
Taze em..TAZE EM ALL!!
A man that builds a thousend bridges is a bridge builder, but a man that sucks one ( blank ) is a ( blank ) sucker.
It looks like the 4th of July from my rear view, how about from your view?
Old 12-07-2008, 09:03 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Can an injector bung be welded to the long neck portion of the intercooler just above the throttle body and still work properly?
I'm just thinking this would be easier to do.
Old 12-07-2008, 09:19 AM
930gt-40r's Avatar
A930ROCKET- Did you break the rear tab off of your Kokeln or is that another I/C- I broke the same mounting location off of my Kokeln and I repaired it.
As for meth injection- If you could guarantee even distribution, Meth injection not only cools everything it contacts, it raises the spark point of whatever fuel you are running, and it cleans everything it comes in contact with. Methanol injection is the $hit to have- there doesn't need to be any testing to prove that it is great, just look at the STI and Evolution guys who make race-gas numbers on pump-gas with meth-injection.
However there are draw-backs: Refilling, added complexity, oil contamination, and uneven distribution depending on situation. If I go to do one of these setups in my car, I am going to run individual jets per cylinder to make everything consistent. Once I have made sure that everything is even, then I would concentrate on tuning every last horse out of the car through ignition timing and maybe pulling a little fuel out here and there. I know it sounds like over-kill, but think about nitrous guys- they run direct port shots (which is THE safest way to run spray) to guarantee equal spray per cylinder. Call me insane, but that is my take on it.
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-07-2008, 12:31 PM
Acceleration Junkie
Snow Performance's Installation Instructions state "perpindicular" to airflow. Your proposed nozzle location seems appropriate.
Old 12-07-2008, 12:38 PM
A930Rocket's Avatar
That's the way it came.
I'd like to say I had the talent and money to go with individual injectors, but I have neither. The timimg will stay the same but like a bigger I/C, ths will help with temps and prevent detonation.
Old 12-07-2008, 04:33 PM
A930Rocket's Avatar
Thanks Chris.
What's the other device near your meth injector?
Old 12-07-2008, 04:35 PM
Acceleration Junkie
Thanks Chris.
The pressure transducer that feeds the Zeitronix data logger.
Old 12-07-2008, 05:39 PM
930gt-40r's Avatar
Dont say you dont have the skill- you do-
Now the money thing- yea... I kinda got the same problem.
Kris @ Tech9
86' 930/GT-40R Sold
Old 12-07-2008, 06:00 PM
