-   -   Taking off Exhaust (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/445714-taking-off-exhaust.html)
Tug68 12-10-2008 11:51 AM
Taking off Exhaust
I`m new to P- cars hope someone can help. I want to remove the exhaust on my 930. Do I need to take off the bumper to get it off?
sand_man 12-10-2008 12:05 PM
Are you trying to remove the exhaust muffler from the turbo? Or the exhaust headers from the cylinder heads? If it's the turbo, I think it's easier/better to just remove the back bumper. I hate trying to fight with it. Plus, if you still have the lower valence, heat shield, and bumper pads still in place, rear bumper removal is almost a requirment.
There are four nuts (two on each side) under the rub strips on each side of the bumper pads. You will also need to remove the four nuts (two on each side) on the inside of the accordians, and carefully pry them from the rear bumper. Then you have to disconnect the rear tag light.
sand_man 12-10-2008 12:07 PM
Now that I've posted that, I'm trying to recall if there is enough room without having to remove the back bumper. My rear bumper is pretty well stripped and I have a very small muffler, so I'm able to leave my bumper in place.
lucittm 12-10-2008 12:55 PM
It seems like a hassle to remove the rear bumper, but you will be so glad you did. It makes working on the rear of the engine a joy. Well, almost...
Good Luck,
Mark
Benny771 12-10-2008 02:04 PM
No, you don't need to remove the bumper. Just did it a few months back.
You may need a torch to heat the bolts, but thats it.
There is one bolt thats tight to get at ,once you loosen it, its easy.
G/L
sand_man 12-10-2008 03:08 PM
I agree. The access to the turbo is very good this way.
Good Luck,
Mark
zcoker 12-10-2008 04:09 PM
Wait a minute. Last time I looked at the turbine exhaust flange on a 930, there is the back bolts on the muffler flange hidden against the motor that appear impossible to remove with anything. It seems that the whole exhaust section needs to be dropped with the turbo as a whole assembly. What is everyone else using to get those back bolts out to remove just the muffler?
RarlyL8 12-10-2008 05:04 PM
Removing the bumper is not mandatory. You don't even need to jack up the car.
- Remove the heat shield.
- Remove the 5 pounds of gravel you just dumped on your face.
- Remove the valance.
- Remove the muffler strap.
- Remove the Air Injection nut (if applicable).
- Using a stubby 14mm box wrench or ratchet remove the 4 muffler bolts.
- Remove the cat/muffler assembly as one.
Here is proof that you can even remove the turbo with the bumper on. Believe me, if I can do it you can do it.
http://forums.pelicanparts.com/uploa...1228960889.jpg
sand_man 12-10-2008 07:16 PM
Definitly several ways to skin the same dead cat. First time I ever did it, I left the bumper on and removed the valence and heat sheild. I fought with it until I realized how quickly you can get that bumper off. I was amazed at how much of the rear engine was/is exposed this way. Not to mention, the valence, heat shield and bumper teets all just stay attached, and come off with the bumper as a single unit. YMMV.
sand_man 12-10-2008 07:20 PM
An old picture (I'm now running a RarlyL8 center exit muffler/zork) to show what I mean:
http://img59.imageshack.us/img59/690/11ol9.jpg
Emission 12-10-2008 08:19 PM
Ain't that the truth!
I leave the bumper on when I swap my exhaust.
- Mike
Tug68 12-11-2008 05:16 AM
Thanks for the info. I have an aftermarket Borla and I want to take it off to have it polished.http://forums.pelicanparts.com/uploa...1229004996.jpg
equality72521 12-11-2008 05:25 AM
I removed my stock muffler by just removing the valence.
sand_man 12-11-2008 05:38 AM
I removed my lower valnce and heat sheild so long ago (kept it off), I can't remember now...but isn't there a valence screw hiding under each bumper pad? I'm telling you, you will save yourself some trouble, by removing the bumper.
As I said beore, my rear bumper is pretty naked (no pads, no valence, no heat shield)...so there is TONS of room. I no longer remove it either when I work on the muffler/turbo. In addition, my turbo and muffler have been removed sooooooooooo many times, the nuts are not frozen or galled, so this also makes it easier.
equality72521 12-11-2008 06:11 AM
Not on mine, but then mine has Euro pads.
sand_man 12-11-2008 06:12 AM
Originally Posted by equality72521 (Post 4354116)
Not on mine.
But you probably have smaller Euro bumper pads.
equality72521 12-11-2008 06:13 AM
Ha, you beat me to it before I could edit. :)
Tug68 12-11-2008 10:02 AM
So if I take off the lower part of the bumper(valence) I should have no problem getting it off?Also are there screws under the bumpers for the valence? If so how do the bumpers come off. Thank`s in advance.
A930Rocket 12-11-2008 04:34 PM
Read Sandmans first post.
RarlyL8 12-11-2008 05:47 PM
Tug,
This is one of those deals where you just jump in and do it.
On your own picture you can see the large bolts holding the valance on. You simply unscrew them and the valance and rubber come off. It is easier if you take the heat shield off first.
If you wish to remove the bumper as one unit you must first remove the heat shiled to get to the nuts that remove the bumper boobs that must be removed to get to the nuts that hold the bumper on.
Be careful when removing the accordians on each side as the little bolts can scratch your paint.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
