Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
sjf911's Avatar
Turbo support bracket non-OEM
Those of you running non-stock turbo's (V-band turbine outlets, etc.) that won't bolt to a stock 930 turbo support, what have you done for turbo support brackets or hangers?
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 12-14-2008, 03:28 PM
I have no bracket..
Old 12-14-2008, 04:07 PM
sjf911's Avatar
LOL, I guess that is the default option. That does beg the question of what effect that has on header durability and is it a reasonably safe option for the long haul. So how many people are running around without any turbo support?
Sapere aude
Old 12-14-2008, 04:16 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
No turbo support here.
Old 12-14-2008, 04:23 PM
Crotchety Old Bastard
RarlyL8's Avatar
Some 930 tuners toss the bracket when installing a non-stock turbo rather than take the effort to do the job right. Time, heat cycles, weight and vibration strains the entire system. Porsche didn't put that bracket there for looks.
If you cannot use a bracket, for whatever reason, then a really secure muffer strap will help.
Could this be one of the reason aftermarket headers seem so prone to cracking?
Old 12-14-2008, 04:34 PM
David's Avatar
I added a little bracket to my muffler flange:
2014 Cayman S
2011 Cayenne Turbo
Old 12-15-2008, 04:17 AM
After the next project
x98boardwell's Avatar
option
I think Chris at Turbo Kraft was going to make an aftermarket bracket at one point. You may want to try him. They are located in Mesa, AZ.
Bryan
Old 12-15-2008, 05:36 AM
"I wuz the liquor..."
sand_man's Avatar
If you cannot use a bracket, for whatever reason, then a really secure muffler strap will help.
^^^What he said^^^
I think a bracket of some sorts is important. When I first installed a K27 based turbo, I left the bracket off, but I was running a B&B muffler at the time and it had a pretty stout clamp that I'm sure helped. However, I never felt good about leaving the turbo bracket off. Thus I modified it to fit and have run it ever since.
-jeff
Old 12-15-2008, 05:40 AM
sand_man's Avatar
One other thing to be aware of is that the turbo bracket uses 3 of the 4 bolts that hold the engine hangar support console to the crankcase. So make sure you don't just leave off this hardware if you decide to ditch the bracket! That would be a Darwin Award winner!
-jeff
Old 12-15-2008, 06:03 AM
sjf911's Avatar
I hear you! However, I am adding a turbo to my modified SC and trying to figure out options. I am using GSF H/E's but haven't settled on a turbo yet. Many of them have V-band or other incompatible outlets which would appear to make using the OEM bracket difficult if not impossible.
Has anyone built a support for a V-band (there is something seductive about the V-band system)? Can you bolt a support to the inlet (T3 flange)? Can you weld a bracket to the turbine housing itself without damaging it?
Sapere aude
Old 12-15-2008, 06:45 AM
RarlyL8's Avatar
Ben with M&K has a v-band turbo on his non-930 engine.
Old 12-15-2008, 07:32 AM
no mine is 4 bolt of the grand national fame but I don't use a bracket. I have good muffler straps though. I will probably will fab one for the 993 HE setup. sjf911 give me a call if you want to discuss options for you sc conversion done this a few times 262-364-7426
Ben
Current project 73 914-6 Gt project rusteration 2.4
Reproduction 914-6 oil tanks, 1-5/8" 914-6 heat exchangers source call 2623647426 or email mbconsulting21 @gmail.com
Old 12-15-2008, 08:59 AM
mark houghton's Avatar
Not using a support on mine either, mostly because it wasn't there when I purchased the car. But, I've got the muffler pretty solidly mounted. Someday I'll prefab something to mount the turbo as well.
Old 12-15-2008, 10:56 AM
Smart quod bastardus
fredmeister's Avatar
I did not run a bracket when I modified to a k27s turbo in 2007.
Have run 15,000 miles since then without a problem so far. Though now I removed the stock muffler and its muffler bracket, to install a home made zork. I plan on making a turbo bracket from simple perforated muffler strap to mount it similar to the stock 3 bolt bracket from Porsche.
I don't think having the weight of the turbo on the end of the GSF headers is a good idea without taking a little weight off of it with even a simple support bracket. I will try to post pix when I have it done.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-16-2008, 09:31 AM
Wo ist die Rennstrecke?
DonE's Avatar
I run a v-band GT35r and use the header to support the turbo. Its been four years and no problems yet. In addition, I built a special support for the muffler that is very stout and adds stability to the muffler and turbo.
Old 12-16-2008, 04:17 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
