Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 / 930 Turbo & Super Charging Forum
550SPYDER's Avatar
Prime the Turbo after replacement
Looking for some "creative" ways or insight on how to best prime the bearings in the new turbo after I install it. - Ryan
___________________
Ryan
2001 996 Twin Turbo
1982 930
Old 12-16-2008, 12:35 PM
Crotchety Old Bastard
RarlyL8's Avatar
With the turbo oil reservior removed, pull the fuel pump fuse and crank the car until oil flows out the bottom of the turbo. I use a large detergent bottle to catch the oil.
Old 12-16-2008, 12:54 PM
550SPYDER's Avatar
PERFECT! Just one question..... any help you can give me on which fuse is the fuel pump would be greatly appreciated.
___________________
Ryan
2001 996 Twin Turbo
1982 930
Old 12-16-2008, 01:05 PM
Wo ist die Rennstrecke?
DonE's Avatar
Inside the hood, driver's side, is a fuse panel. On an early turbo, there are two red round relays towards the back of the panel. Pull them both. If you are unsure, pull the coil wire to the distributor to eliminate a spark.
Old 12-16-2008, 04:21 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
