LinkBack Thread Tools Rating: Thread Rating: 7 votes, 4.43 average.
Me like track days
Craig 930 RS's Avatar
BY your description, its *has* to be alignment as opposed to torsion rates etc
I think you'll find it out pretty quick -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-06-2009, 12:53 PM
TroyN's Avatar
FYI: positive toe measurements = toe in, negative = toe out.
'01 996, w/ LN IMS!
Past: '96 993, '98 986, '82 911, '99 986, '87 930, '86 951, '85 911 GTS3 race car
Old 01-06-2009, 03:56 PM
TroyN's Avatar
Also, what tire pressures are you running? Too high or too low pressures can contribute to what you're describing.
'01 996, w/ LN IMS!
Old 01-06-2009, 03:59 PM
On the camber front, before you start changing things, you should get a pyrometer and take some real tire temp and go from there.
I am running just a touch more negative F/R than you, which sounds insufficient. But when I took tire temp, I'm getting <10deg difference between inside & outside. So, my mechanic & I decided to not mug around with camber.
I also understand different tires like different cambers, so again - take some temp first.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 01-07-2009, 05:49 AM
Smart quod bastardus
fredmeister's Avatar
I think you have it backwards, I have always seen positive toe referred as toe out.
Negative values are toe in.
This is because toe is always the difference between the measurement across the front edges of the tires minus the rear edges distance. If the value is negative the front edge distance is less than the rear.
Another way of looking at it is when looking down on the car as if standing on the roof and facing the direction of travel, the front edges of the tire will be turned towards the center of the car by the angle specified as the toe angle, forming a vee shape more or less.
That is why it is better to give more details about what was measured when talking numbers.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-07-2009, 07:14 AM
TroyN's Avatar
I agree we don't know for sure whether the OP's measurements are toe in or out, but I've experimented quite a bit w/ alignments and positive toe = in. Not that Wikipedia is the be-all-end-all but it's generally right about a lot of things.
http://en.wikipedia.org/wiki/Toe_(automotive)
'01 996, w/ LN IMS!
Old 01-07-2009, 10:04 AM
Hi guys- I went back and looked at the alignment sheet and those numbers look like positive .15* for the left front and .14* for the right front. Toe in the rear says .12* for both. If I remember correctly the tire pressure was set at 29 psi cold and hot pressures went to 37psi. No pyrometer readings taken. It was a DE event at RA last September held by the BMW club. Should of taken readings for reference but like I said it was more of a shake down run for the motor set-up. Didn't think the suspension would be an issue. Motors perfect, handling's not. Thanks-Jeff
Old 01-08-2009, 07:20 AM
Me like track days
Hang tight, I'll give you my exact alignment specs -
Old 01-08-2009, 08:01 AM
Me like track days
2.0 degrees negative camber FRONT
2.9 degrees negative camber REAR
5.5 degrees caster FRONT
0 degrees toe FRONT
.12 degrees toe REAR
Old 01-08-2009, 10:16 AM
Craig- Thanks for digging up those settings. They work well for your car? I will definitely make changes to the toe and put a bit more negative camber all the way around. Loved the vette video. Jeff
Old 01-08-2009, 10:55 AM
Me like track days
Really well. Super stable- as long as the road has no significant crown to it and the road ruts aren't bad.
Otherwise, the hugely wide (275/315) tires really follow the road .... sometimes rather scary ;-)
I'd guesstimate getting rid of that toe will help a lot.
Old 01-08-2009, 11:11 AM
TroyN's Avatar
Craig, to clarify, is your rear toe measurement total across both sides, i.e. .06 each? I need a realignment so may try your settings but not so aggressive on camber since I will not track this car.
'01 996, w/ LN IMS!
Old 01-11-2009, 07:20 PM
Me like track days
Toe Rear: .12 each side. .25 total says the alignment sheet
Camber: For street I'd go 1.0 front, 1.5 rear - negative camber
Old 01-12-2009, 10:39 AM
