gumba's Avatar
DP's & Flatnose front tires
Just some info. I'm in the process of swapping out my 8&11x 15's w/215 fronts & 295's rears for 9 & 11 x 17's 3 pc. fuchs. The rears were fine w/315's. The fronts were a problem. I fit Goodyear eagle f1 gs-d3 255/40/17's which are 25" high. In my situation it interferes with the headlight bucket when the wheel is turned all the way. It would also interfere with the wheel turned most of the way under hard cornering.
I'm switching to an eagle f1 gs-d3 245/35/17 which is the same height as the 215/55/15, approx. 23.8" high. Goodyear is discontinuing this tire. The next choice would be a 235/40/17, approx. 24.4" high, but not sure if that would work.
Looks like the Michelin TB15's are good for approx. 5K miles. The fronts and rears have worn the same. At $2200.00 for a set, I'm not anxious to replace them.
The clearance problem could just be specific to the DP's. Any of the Flatnose crowd having the same problem?
'79/930 DP935
Old 01-11-2009, 11:15 AM
Forced Induction Junkie
WERK I's Avatar
Yep, same problem. I have 235/45 x 17 (8 in.) (24.8 in. high) on the front of my slant. They rub on the front wheel well splash panel on tight turns.
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 01-11-2009, 01:49 PM
I have the same problem with 245x45x17 on my 1987 factory slant. I am considering 235x40x17 but haven't tried them yet.
Old 01-12-2009, 03:51 PM
gumba's Avatar
I'm not sure if the 235/40 would clear in my case, so I figured I would start with the 245/35 which I know will work. Hopefully I'll have them mounted by the end of the week.
Old 01-12-2009, 05:04 PM
mine rub with 225 /50 /16 my other p car has no problem with 245/40/17
Old 01-12-2009, 06:35 PM
