930gt-40r's Avatar
Headers are cracked, need suggestions
My headers are beat and I need to get a new set of single turbo headers.
If any one has a used set of units with 1 3/4 primaries and or knows where I could get a set. I would prefer a set with a T-4 flange but beggars can't be choosers. Ultimately I am looking not to get beaten over the head with the cost.
Any help or suggestions are appreciated.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-19-2009, 09:08 AM
What type headers did you have before? Just curious why they would be cracked...
Old 01-19-2009, 10:50 AM
930gt-40r's Avatar
They were B&Bs (thats all the reason for cracking...) that I had modded for T-4 and v-band waste gate. They cracked on the inside of the merge collectors and I tried to have them fixed but no good. I figure this is the right time to go with bigger primaries.
Kris @ Tech9
86' 930/GT-40R Sold
Old 01-19-2009, 11:01 AM
MN
Sarah's Avatar
Not that this helps much...but i'm having my B&B headers changed out this spring and going back to stock. There is an exhaust leak & ticking noise. (I really like my GHL dual outs though so I hope all is well once this gets done). Good luck w/ your project.
87 930 Blk/Blk
Old 01-19-2009, 11:36 AM
Metal Guru
911nut's Avatar
Sarah, before you do that, check this out:thoughts on 993HE vs ssi(turbo HE)
You could also buy the SSI/M&K set-up also vs. returning to stock.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 01-19-2009, 11:38 AM
MN
Sarah's Avatar
thank you for the extra info. I will chk it out. the 930 will be sleeping another few months so I have time to gather more info before it goes into the shop.
87 930 Blk/Blk
Old 01-19-2009, 11:43 AM
930gt-40r's Avatar
thank you- you likely have the same problem as I did with the crack inside the merge collector- if the heater boxes are retained- B&B charges about $600 to fix the problem.
Before I de-boxed mine- I was waking up with wicked headaches the morning after I drove my car due to all the CO.
Kris @ Tech9
86' 930/GT-40R Sold
Old 01-19-2009, 11:44 AM
E-85 sippin drunk
turbobrat930's Avatar
930GT, why dont you make your own?? A pair of Burns Stainless v-band merge collectors are about $700.00 a apir, then you would have about the same in 321 SS tubing... cut, weld, and for under $1500.00 you could have a custom set...
just making you think about another option, as I feel that almost anything is better than the BB option....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 01-19-2009, 01:34 PM
930gt-40r's Avatar
This is also a viable option, I am thinking about that option more and more. I do not have a Tig welder so it could prove to be very hard, but i could tack things in place and have a friend weld it. If I cant find a good set of Holcombs or something equivilant I will make my own.
Kris @ Tech9
86' 930/GT-40R Sold
Old 01-19-2009, 01:53 PM
why not the 993 HE solution? I would think it would work well
Ben
914-6 2.4s GT tribute.
914-6werkshop.com manufacturer of 914-6, GT, Conversion parts
Old 01-19-2009, 02:20 PM
930gt-40r's Avatar
Hmm- its possible- could I get it with a t-4 flange? What size are the primaries on those? I promised myself that I would not go with the stock size when I replaced the headers. I am pretty sure the 3.6 headers have to be a little bigger than stock 930 primaries. Ive seen the thread on them and it looks like a good deal. I am ultimately looking for 550-600 on pump gas. Let me know the price
Kris @ Tech9
86' 930/GT-40R Sold
Old 01-19-2009, 04:15 PM
the y is 1250 with wastegates included. the heat exchngers range for 450 - 650 with the flanges rotated I will have to measure primaries again but I think it was 1 5/8ths but it escapes me this early
Ben
Old 01-20-2009, 02:38 AM
