There is the end result on mine. In addition to 40* cooler at the track.
Old 01-29-2009, 03:17 PM
Garrison's Avatar
Miguel, this is something that you built yourself? Just wondering as that is what I thought from your previous post.... if so, please do tell how.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 01-29-2009, 06:05 PM
Yes DIY. I struggled with the aftermarket front valances look, they all are too bulky/plastic/aftermarket looking to me. Therefor, dealt with the high oil temps for a long time... until something really had to be done to go to the track and have "piece of mind" regarding oil temps. I took the valance off and install the oil cooler - on front of the tub leaving an inch of clearance between the tub and the back of the cooler for air flow - I had to cut a notch on the bottom of the front bumper to allow the cooler to go through (about 1") allowing enough room to clear the bottom of the valance flange where the OEM rubber lip connects to - this notch is about 17" long and 1" wide. I connected the oil hoses in parallel with the fender cooler - BTW the upper hose of the front cooler runs inside the bumper and the bottom hose coupling can be seeing (shinny) on the above picture. Then, I took the car to a body shop, obviously without front valance - cool looking thing! and worked with the guy there to cut and shape the OEM valance around the cooler keeping the mounting brackets and rubber lip mounts intact - some craftman work here but CAN BE DONE. I'm satisfied with the look, and glad you guys like it, but better yet is the oil temps at the track, whatever I do they stay below 210*.
Old 01-30-2009, 04:06 AM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Miguel
Do you have any close up pics?
Old 01-30-2009, 07:00 PM
What about this one?
Old 01-30-2009, 07:17 PM
I had a DP front spoiler and Setrab on my 930 and it never ran hot, it also had a radiator type cooler in the right fender. Are the yellowbird front spoilers still available? Nice because they flexed.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 01-30-2009, 07:33 PM
Blackbird Pilot
Reaper930's Avatar
Originally Posted by Craig 930 RS View Post
The 930 I own has 3 oil coolers and I need every bit of them for track days - granted, it is pretty high hp comparatively.
Amen to that. 3 coolers here as well - cheap insurance for track use.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 01-31-2009, 02:05 AM
A930Rocket's Avatar
Is that three up front plus the engine mounted oil cooler?
I bought another fender mount oil cooler (to add to my stock and front coolers) but did not mount it when temps seem to be ok at the track. I'm at 400 to the rear wheels.
...The 930 I own has 3 oil coolers and I need every bit of them for track days - granted, it is pretty high hp comparatively.
Old 01-31-2009, 05:44 AM
Me like track days
Craig 930 RS's Avatar
Reaper sure did it right with those 3 oil coolers, nice job too!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-31-2009, 09:31 AM
