Garrison's Avatar
front mount oil cooler???
I have recently purchased an 83' 930 and am wondering if a front mount oil cooler would be recommended for the track days that this car will see? Prob 4-6 DE's this summer that are already on the books.
If so, what brands, make, etc. would be recommended?
The car is stock except for a complete top end and rebuilt turbo.
Thanks.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 01-26-2009, 01:32 PM
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
I would say yes. The cooler you can keep the oil the better. I have a Setrab, but the model number escapes me. It's at least 20-22" x 6" x 2". Use -12 lines at a minimum.
Mounting it is not a problem but do you have an air dam that allows for an oil cooler opening? Or will you modify your valance?
Old 01-26-2009, 03:37 PM
After the next project
x98boardwell's Avatar
I think
I think the setrab is a 172 model number. I dont have one but have looked into it in the past.
I will check and chime back in when I have the info.
Thanks,
Bryan
Old 01-26-2009, 05:24 PM
Garrison's Avatar
Thanks guys! The car currently has the stock front valance so I will need to change that out as well, or modify mine to work.
1996 Porsche 911
Old 01-26-2009, 05:42 PM
Me like track days
Craig 930 RS's Avatar
For track use, you will definitely *require* an oil cooler. There is literally no way your car will survive - no exaggeration - track use without one.
Unless you like 15 minute run sessions ;-)
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-26-2009, 06:52 PM
Garrison's Avatar
The local PCA group does 18-20 minute run sesions so I might get lucky in the short term, but I am thinking long term here for sure.
I know the trombone cooler on my 88' 911 was enough for that car, but with the heat that the turbo creates I am sure the 930 will not be as lucky with the factory cooler.
1996 Porsche 911
Old 01-27-2009, 05:34 AM
Me like track days
For me, the biggest shortcoming a 930 has is the oil temp problem - it is huge.
Old 01-27-2009, 10:02 AM
Garrison's Avatar
Is the Setrab that the guys speak above a good choice for someone that will be driving the car on the street mainly, but will also be looking at 4-6 DE's a summer?
Any others that might be worth considering?
1996 Porsche 911
Old 01-27-2009, 10:43 AM
Turboo934's Avatar
Cristine has a fender mount with a fan and one in the nose. More oil = more cooling 180 on hot day running hard. She's also running on Aero Shell aircraft oil,it is made for air cooled piston motors.running Turbo
Old 01-27-2009, 12:33 PM
Porsche-Poor
bcoats's Avatar
you will need at least 2
1979 911 RS clone hotrod
1983 930 turbo-sold, will be missed
1992 964 C2 Coupe-regrettably sold
1980 911 SC Weissach-regrettably sold
1975 911S-sold but not forgotten
Old 01-27-2009, 12:40 PM
Smart quod bastardus
fredmeister's Avatar
Setrab-172 is the biggest oil cooler that will fit in the normal array of lower valences with provision for central mount coolers.
The trombone is useless in the turbo.....at least get a Carrera cooler with fan for most city driving and traffic duty.
For track work you will need this and a front mount cooler.
Currently I run 6-10 DE days per summer and after 10-12 minutes or so the oil in my 79 930 with the above mentioned Carrera cooler was approaching 240 degrees. My car is putting out about 360h.p. with the mods I have got, and this is directly related to heat that goes into the oil that is basically cooling your engine.....along with the air from the fan. Did I like the fact that now I gotta install another front mount cooler and replace my stock lower spoiler....NO!
But you do what you gotta do to get the oil temps down to under 210-220 degrees.
----why not install the biggest oil cooler you can then? Elephant racing has nice pictures of an install and sells a good kit....sorry about advertising for a competitor to Pelican, but trying to give you some helpful info on these forum.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, B&B intercooler, Snow Perf water/meth injection, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.7bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-27-2009, 01:43 PM
Garrison's Avatar
Thanks guys. This is good information. I was assuming that the turbo would come close to the top line in temps when at the track...but did not know the extent of it. You have shed some serious light for sure.
I guess this might be the first mod to the car then... Are their any write up on installing a fan for the Carerra cooler, etc.? Just wondering if anyone has the links off the top of their head?
1996 Porsche 911
Old 01-27-2009, 02:19 PM
Me like track days
It is. It's a day-ender or at the very least a session-ender for sure.
Makes you wonder how these things left the factory and passed sustained full-throttle tests on the Autobahn etc etc in the first place......
Old 01-27-2009, 02:47 PM
There is an option, install the cooler modifying the OEM front valance. Temps at the track went to 180* from 230 before.
Old 01-27-2009, 03:14 PM
Porsche-Poor
bcoats's Avatar
in the ongoing quest for lower engine/oil temps, are those fin type coolers that replace the "S" shaped oil line any good in addition to say the stock and a front mounted oil cooler? My buddy runs one on his vintage 911 race car and swears by it???
Old 01-27-2009, 04:00 PM
A930Rocket's Avatar
Miguel
Do you have close up pics of yours for reference? Seems like a great option for many.
There is an option, install the cooler modifying the OEM front valance. Temps at the track went from @180* from 230 before.
Old 01-27-2009, 04:16 PM
A930Rocket's Avatar
bcoats
Are you asking if replacing the stock fender cooler with a finned tube cooler vs a Carrera and front oil cooler would be enough? There's not much air flow at speed and certainly at a stand still that I would feel good about either type fender oil cooler only for the track.
No experience or knowledge on how effective a finned tube cooler is.
Old 01-27-2009, 04:23 PM
Send a message via AIM to EPorsche
My 02 cents. I would suggest the Setrab 272 (I think). The same size as the 172 but diaganol for more cooling efficiency. If I had to do it again, and I might, I would go with AN16 fittings instead of the AN12 ones I have.
'77 911S w/'81 3.0/MegaSquirt/MSD
'81 911SC stock
Old 01-27-2009, 04:41 PM
Garrison's Avatar
This is why I love this board... learn something new everyday from people that have been there before. Sometimes 2 or 3 times before.
I would be interested in seeing pics of your "modified" front valence Miguel as well. That might be an option until I can get the front valence and cooler I want.
1996 Porsche 911
Old 01-27-2009, 05:33 PM
Me like track days
Bryce - Not useful for our cars.
930s heat up the oil in extreme amounts, this would not work for us.
The 930 I own has 3 oil coolers and I need every bit of them for track days - granted, it is pretty high hp comparatively.
Old 01-27-2009, 06:59 PM
